How accurate are h/p calculators?
Old Dec 6, 2002 | 02:38 PM
Narcah's Avatar
Question How accurate are h/p calculators?
Such as the one at DSM.org? I'm trying to get a handle on my power without dynoing it. I assume it's somewhat accurate right? Thanks
Old Dec 6, 2002 | 02:44 PM
stonedchihuahua's Avatar
How accurate are hp calculators???
Umm NOT VERY
Old Dec 6, 2002 | 03:39 PM
Marc 85Z28's Avatar
Usually, not very good. That ET method is crap - BUT, MPH wise it rates your car as 235HP. That's pretty damn accurate if you ask me. Do you have a single cat? Your rated at 230, and add the minimal mods...
I've always thought my car had around 270HP (99-100MPH traps), but according to that calculator I have 275HP
Old Dec 6, 2002 | 04:48 PM
MRZ28HO's Avatar
Exclamation
Only the MPH method comes close, ET wise has too many variables to be accurate. Not even dynos are as accurate as can be. These HP calculators help you figure out how your car is responding to mod, but not to tell your friends "Hey I have 300 rwhp ... this calculator says so".
Old Dec 6, 2002 | 05:16 PM
CODY BEHNKE's Avatar
They are about 1% accurate, No formula can include all of the variables.
I guess the way I see it is go to the dyno or take it to the track.
Old Dec 7, 2002 | 10:20 PM
beaux's Avatar
WOW....if the MPH method is pretty close. Then my 305 in my El Camino has exactly 100hp....LOL ran 19.5 @ 71mph....and is 3550lbs......Wow that sucks.
Old Dec 8, 2002 | 12:06 PM
GMTech's Avatar
Here is another: http://sethirdgen.org/hpcalc.htm
They are not very accurate. They all use a common formula, but it cannot account for many of the variables that exist in drag racing. All the calculators said I should have 307 RWHP, but at the dyno, I only put down 271. HUGE DIFFERENCE!!!
Old Dec 14, 2002 | 09:40 AM
JMSILVER23's Avatar
not very!
HP calculators are missing a very important peice of info Weather. Using a et predictor at the track it said my car was making 420hp to the ground. With the moroso hp slide ruler using the same times it said that it makes 385. If the car ran those times at sea level the slide ruler would be accurate.
Jason
Nayr
Mar 3, 2023 08:34 PM
4586
Aug 13, 2015 10:11 PM
97ZBOY
Feb 6, 2003 02:39 PM
menlatin
Advanced Tech
Dec 31, 2002 02:22 PM
stevil
13
Sep 24, 2002 11:31 AM
