4th gen rear end swap
Old Nov 27, 2002 | 07:36 PM
Gixxerthou's Avatar
Lightbulb 4th gen rear end swap
alright,I found out as of late that my car(89 IROC L98)has a crappy 9 bolt rear end that i can't get any gears for.....so.....i'm gonna be looking this weekend for a rear end from a newer camaro-10 bolt.and getting some 4.10 gears.will the new rear end fit right?(i'm planning on getting the entire rear end with discs)how much would it run me?-sick and tired of my 2.77s that came in the car.i need some in town stomp if ya know what i mean! any info would help.
Old Nov 27, 2002 | 08:04 PM
TheGreatJ's Avatar
The 4th gen rear will bolt right in, but its wider than the 3rd gen rear so your tires will stick out 1-1.5" farther on each side. If you're changing from drum to disk you'll also need a proportioning valve (that block of aluminum under the master cyl) so the brakes will work right.
You can find a rear for anything between $150 and $400 depending on what shape its in and what equipment it has...you can expect another couple hundred to purchase gears and have them installed. If all you need is gears you'd be better off getting a set of gears for the 9-bolt from Diff Solutions for about $300 and having them put in, but if you need the disc conversion too then the 4th gen rear is the way to go. You can always sell the 9-bolt for a couple hundred to help offset costs.
Old Nov 28, 2002 | 10:22 AM
87camracer's Avatar
another thing, i wouldnt go with 4:10's, those gears are WAY too steep for a stone stock TPI. now if yo uhad a higher revving engine, they would be nice because they would get you in you peak power faster. for a TPI i would suggest a set of 3.42's. go to www.slponline.com and look for their take out rears, they are the stock 3.42 posi rears from the new z28's that were converted to an ss. if you can get a rear from a 90 or newer third gen its a direct bolt in. it will also be a 10 bolt like the 4th gen but will actuall be a direct swap. if you find one from an older 3rd gen then you will need to switch to 28 spline axels before you swap in the take out posi. BTW those posi's go for around 100 bucks depending on what you get...
Old Nov 29, 2002 | 05:08 PM
Zepher's Avatar
I'd keep the 9bolt since it is much stronger than a 10bolt. Just pay the little extra for the gears for the 9bolt.
Strength-wise from weakest to strongest is, 10 bolt, 9 bolt, 12 bolt.
Old Nov 29, 2002 | 06:18 PM
camaroz28racer2's Avatar
www.9bolt.com <-- gears for your 9 bolt
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
ModdedNerd
Dec 25, 2014 05:51 PM
