Detonation sucks.
Old Nov 30, 2002 | 05:03 AM
oil pan 4's Avatar
Unhappy Detonation sucks.
I get that good old ratteling sound from the engine when I step on it when I'm going down the inter state.
I blame the 3.08's, the auto trans that dosen't like to down shift and no CAI.
It kind if drags when it detonates, that's what sucks.
What could I do to fix it besides 89 or 92 octain gas?
2 things I don't realy know that good are heli's and auto trans.
Also my trans is shifting in and out of park kind of hard and it won't let me put the shifter down into 1st and 2nd and some times I can't get it into 3rd (regular drive, OD works fine).
I'm guessing it's linkage or it wasn't hooked up/ajusted right when the trans was put back in. Any one know what could cause the shifter to be a pain in the @$$ like that?
Old Nov 30, 2002 | 06:51 AM
aklim's Avatar
I don't think this has anything to do with your gear ratio or auto trans. The linkage might not be adjusted right but I won't know it till I see it.
Perhaps it is the carbon buildup in the cylinders or maybe the injectors are clogged or you don't have enough fuel.
What engine?
Old Nov 30, 2002 | 12:22 PM
SS CAM's Avatar
Running the highest octane you can will help, but I'd look at your timing and see where it is at first.
Old Dec 1, 2002 | 03:52 AM
oil pan 4's Avatar
I still have not got en the casting # so it could be a 305 or 350, what ever it is it's a farly new engine, i don't think there could be to much carbon build up.
When its warmed up and ideling it smells rich. It drinks plenty of gas too.
Old Dec 4, 2002 | 06:30 PM
1985camaroz-28's Avatar
id say trying getting a good thermostat,that should help if the problem is detonation
Old Dec 4, 2002 | 10:58 PM
MrsLottaBalls's Avatar
Check your O2 sensor. Also, make sure you don't drive the car too soft. I got a decent amount of carbon buildup in my RS (which is sitting with a spun rod bearing right now) from babying it all the time and never getting above 2500rpm. I don't have that problem in the IROC...
Kawi
Sep 28, 2015 09:01 AM
az1gplus
Feb 7, 2003 01:38 PM
rncotton
Sep 8, 2002 08:48 PM
CLEAN
Aug 20, 2002 12:45 AM
tbyrne
Aug 16, 2002 01:12 PM
