Caliper Switch from 1988 to 1982
Old Nov 15, 2002 | 07:52 AM
Digitali's Avatar
Has anyone successfully switched out the front disk calipers from a 1988 Z-28 to a 1982 Z-28?
Are there any mods that need to be made or is it a simple pull out and install?
Thanks.
dB
Old Nov 15, 2002 | 11:00 AM
Digitali's Avatar
Answer
I've found an answer here:
http://www.thirdgen.org/techbb2/show...r+switch+front
Apparently, "Front Disc:
All non 1LE front calipers, 84-92 are identical.
Non-1LE front calipers 82-83 were a different thread for the brakelines (SAE instead of metric); this makes the rubber lines non-interchangeable. I don't know if the banjo bolt threadings in the calipers are different are not.
All 1LE calipers are identical.
Rear Discs:
All 89-92 calipers should be interchangeable.
All 84-88 calipers are interchangeable
82-83 calipers are interchangeable.
82-83 are not interchangeable with 84-88 due to the SAE vs. metric fittings problem.
'89-92 read discs will mount on an '82-'88 rear (and vice versa) assuming you swap the backing plates. 9 and 10 bolt backing plates are different. You'll also have to swap hard lines (or fabricate your own) and rubber caliper lines (not the center one)."
Just in case someone does a search for the same thing.
dB
Ericksd
Jan 20, 2016 06:07 PM
IndyZman
Oct 22, 2015 02:17 PM
94Z28LS1toLT1
Sep 22, 2015 05:24 PM
Rod Bender
25
Sep 16, 2015 01:47 PM
jackpawt883
Sep 10, 2015 08:53 PM
