It's only a broken moter mount
Old Nov 11, 2002 | 11:56 PM
oil pan 4's Avatar
Thumbs down It's only a broken moter mount
I found a broken motor mount on the driver side if I get some $50 polyurethane Energy Suspension mounts can I reuse them if i drop in a power full stroked 350 and reuse the mounts?
Or should I drop in 2 sets of rubber ones( one now and another set later on with the new engine)?
The rubber mount is totaly gone.
Old Nov 12, 2002 | 01:41 AM
Chuck!'s Avatar
I dont see why you cant reuse the poly ones. Hell I reused the rubber ones after I had my engine out.
Old Nov 13, 2002 | 12:04 PM
Marc 85Z28's Avatar
Sure you can. I've got the ES mounts on my car. They don't wear out and sag like rubber - and I seriously doubt they will break
Old Nov 13, 2002 | 12:13 PM
badassT/A's Avatar
I just started redoing mine and am putting in Prothane inserts into the original housing. Basically all you have to to do is grind down the rivets on either end and then drill out what left in the center a bit. The Prothane inserts are very nice pieces.
G-BODYT56
Jan 14, 2022 11:14 PM
alliance12364
Sep 23, 2015 12:40 PM
mmf_1013
Sep 12, 2015 08:56 PM
Toxintwins
Sep 11, 2015 11:13 AM
Daluchman1974
Sep 11, 2015 06:12 AM
