wheel and tire combo
Old Dec 1, 2002 | 12:49 PM
speedfreak85's Avatar
What is a good size of wheels and tires for my 88 camaro? I know I want 15" rims, just not sure how wide. How big can I fit on the back?
Old Dec 1, 2002 | 06:32 PM
stevem's Avatar
i run 265 50r16 on stock irocs
they rub a little when i am driving hard but i need to replace bushings
it all depends on your offset some people run 275 without rubbing
hope it helps
Old Dec 2, 2002 | 06:08 AM
How about a max rim width for the back and a good size for the front?
Old Dec 3, 2002 | 02:42 PM
Ok, I think stock rims are 8" right? Is that the widest I can go or can I go 10"?
Old Dec 3, 2002 | 10:14 PM
Z28tt's Avatar
You can run 17x11's front and rear w/ some fender modifications, or squeeze in 17x10's up front and 17x11's in the rear w/ no modifications. The backspacing has to be right on, though. Go for 17x9.5's for an easy fit
Old Dec 4, 2002 | 03:38 AM
aziroc's Avatar
i just put in my 15x10 cragar street star's w/ 26x11.5x15 ET streets. the rims have like 4 3/8"*or its 4 1/8, i forget* backspacing, so the tires stick out about an inch, alittle less. but i have some room before the tire hits the wheel wells on the side. i will have to say imo that when i get my 17x11's, that ill be pushing it for room under there. but i ahve seen many 17x11 rims on 3rd gens with no problem. i may try some 15x12's and c how they do.
carguy0119
Apr 11, 2016 11:11 PM
dpw21562
Jan 23, 2015 04:58 PM
hotrodyou1
Dec 20, 2014 10:05 PM
globalprojeff
Dec 6, 2014 04:18 PM
globalprojeff
Wheels and Tires
Dec 6, 2014 04:09 PM
