Carburation Intakes
Anybody out there ran both the Performer RPM and the Action Plus? Looking for a intake to use on a 350 chevy with Sportsman 2 heads, 2600 rpm converter, and 3.23 gears. Trans is a 700R4.
What do ya think???
What do ya think???
Originally posted by Squeeks83
well i have the preformer, but on my new engine i am going with the preformer air gap intake from edelbrock, and a 750 carb, on my 355. but the preformer is a good intake manifold.
4yhmn ,k
I got a feeling you'll need an RPM style intake that'll get you 6500 or so RPM since those heads are pretty big(200cc intakes, right?) for a 350 cube motor. It really only matters if you are looking to get the most power possible out of the combination. Big heads/big cam/small cubes=Big RPM power with the right intake and headers
Bottom end torque is sacrificed a little bit but that 2600 rpm stall you have is the perfect answer
Goodluck and happy motoring!
Mine fits fine with an Edelbrock 750, 1" drop base cleaner, and 14x3 K&N. Had to use a banjo fitting on the fuel inlet to get around the drop-base, but thats no big deal. Just make sure your air cleaner stud doesn't extend more than 1/4-1/2" above the cleaner lid.
