Question on this rearend
Old Nov 8, 2002 | 01:02 PM
BlowBye's Avatar
Im buying this rearend from an 87 firebird, Its 3.42 non posi drum, The price is very good and i dont need anything crazy, but what im concerned with if its a 26 or 28 spline? Any ideas or thoughts? i hope its a 28.
Old Nov 8, 2002 | 04:09 PM
tmple of torque's Avatar
if its from an 87 model its a 26 spline!
now if you find a rear end from a 91 -92 model rs or z28 you have the 28 spline.
Old Nov 8, 2002 | 04:33 PM
88 427 Camaro's Avatar
Or if you find a borg warner 9 bolt, it will also be a 28 spline regardless of the year.
Miles
Old Nov 11, 2002 | 09:22 AM
Ucantcme57's Avatar
What is a "Good Price" to you??? I bought my rearend our of a 35th anniversary Camaro with 3.42's EATON posi 28spline axles 2 piston pbr calipers and 11" rotors for $250.. There are deals like this everywhere..
K
Old Nov 11, 2002 | 09:42 AM
rickyzZ28's Avatar
Like 88 427 Camaro look for a 9 bolt. I got mine for 150 with older brakes on it. Since then I have totally rebuilt the rear with parts from 88 427 Camaro and the shop said they couldnt believe the high quality parts I got. They were very impressed and they are a professional driveline shop. I also pgraded the old style 88 brakes to 93 Z28 brakes.
Old Nov 11, 2002 | 06:25 PM
BlowBye's Avatar
I really dont want a 9 bolt, in most cases there usually lower gears than i need. Im looking for 3.42 rear(posi or nonposi) 28 axle. Some turd emailed me asking $800.00. It wasnt a posi and it was drum. I wish i could find a deal like that.
Old Nov 14, 2002 | 08:22 AM
87iroc-vert's Avatar
I'm looking for a deal like that... looking for 3.42, posi, disc, rear end for my 87. would 4thgen rears bolt right up or is there mods?
+ where can I find a rear that suits my needs?
Old Nov 14, 2002 | 07:54 PM
TheGreatJ's Avatar
The 4th gen rears bolt right in, but you need to keep in mind they are about 2" wider so your wheels and tires are gonna stick out an inch farther on each side.
Old Nov 15, 2002 | 10:02 AM
Ucantcme57's Avatar
But they will still be under your fender, you can increase your backspacing if your ordering new rims, Use 4th gen rim configuration and add 2 more inches of backspacing and throw some 315 or some 325R16/50's or something back there for some real traction..
Old Nov 15, 2002 | 05:43 PM
toneyb35's Avatar
BIG REAREND
Me too. I'm looking for a rearend w/posi and disc for a 91' w/big gears for the highway.
blac94Z
29
Mar 25, 2015 04:21 PM
ddr698
Jan 31, 2015 10:58 AM
89 iroc zl1
Jan 14, 2015 02:18 AM
ddr698
Jan 9, 2015 10:05 AM
Speeds8erM-1
Jul 28, 2002 06:18 PM
