Anyone relocate their battery to the rear trunk?
Old Nov 12, 2002 | 04:39 PM
BlowBye's Avatar
If so what kit did u buy, if u didnt buy a kit what where the measurements for the ground and power? What gauge did u use. Mines is currently in the front driver side and since i plan on installing a Procharger this spring, im gonna need room for a cold air intake. any info would be good
Oh its a 92 camaro.
Old Nov 12, 2002 | 06:44 PM
oil pan 4's Avatar
You will need some very thick wire .25'' at least and the ground you can just use a 4ga to the body.
2 peaces of OO wire would probley do.
I want to do mine and I have about 14 feet of .5'' thich aluminum wire that I got from a construction site dumpster.
Keep the line in side and go through the fire wall don't go over the axel out side the car.
Old Nov 12, 2002 | 08:37 PM
Stephen 87 IROC's Avatar
Is this strictly for street use or do intend to use it at a sanctioned track? Without a proper installation it won't pass a tech inspection.
Old Nov 12, 2002 | 09:55 PM
Zepher's Avatar
I did mine last year.
I used 2guage for the positive and 4guage for the negative from teh battery to the chassis.
I also ran a 4 guage wire from the alternator bracket to the body as well for ground.
I used a marine battery box mounted in the spare tire well for the battery.
Mine isn't wired up to pass tech at a track since I don' t have a kill switch mounted to the back of my car.
I used Welding Supply wire since it is very flexible and I had to run it through the car.
I'll be re-doing the install again to make it nice and neat and use a metal battery box.
Old Nov 13, 2002 | 10:31 AM
88 427 Camaro's Avatar
Info is on my page at www.koolmeister.com
Miles
redleader
Parts Wanted
Nov 13, 2016 02:57 PM
CARiD
Feb 9, 2015 09:35 AM
redleader
Jan 22, 2015 12:05 PM
squarehead
Nov 21, 2014 08:02 PM
Z28STYLE23
Aug 17, 2002 07:40 PM
