SB crank questions
Old Nov 20, 2002 | 02:07 AM
oil pan 4's Avatar
SB crank questions
Out of all the 383 cranks all the ones I have seen are externaly balanced.
I want a internaly balanced one, does any one make them?
If there are 0 balance cranks out there how much more are they?
I don't care for the external balance stuff ( see the internaly ballanced 88' 2.8 motor in my 85' camaro).
Also, when did GM start balancing 305 and 350'?
Was it 87'?
Old Nov 20, 2002 | 07:54 AM
angel71rs's Avatar
Scat makes them. Here is an example of a kit that uses it:
http://www.pmeracing.com/triton/engc.../sbc-33832.htm
I think scat lists a different crank for 6" and 5.7" rods. I guess balance on these is that critical when going to internal with the longer stroke.
Sbc's have always been balanced from the factory.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Brandon Wittmer
Dec 20, 2014 09:51 PM
Queens94z28
Dec 20, 2014 09:11 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
