Front end issues, what do you think it is?
Old Dec 2, 2002 | 02:25 PM
newby's Avatar
Alright, my car has been parked for quite a while because of this, so I really want to get it fixed. If I drive it, I get a pretty bad thump/clank from the front drivers side wheel.
I pulled the wheel and the hub was loose, so I pulled the dust cover and tightend the nut and I wasn't able to jiggle it anymore, so I put the wheel back on and tested it. I drove about 50 feet, and it started doing it again. Put the car up on the jack, and I could wiggle the whole wheel.
Someone suggested that maybe it was a bearing issue. Any ideas?
Old Dec 2, 2002 | 07:24 PM
aklim's Avatar
Take it out and see. I think it is a bad bearing but until you take it out, you will never know. If it is, the problem is solved. If not, you needed to repack your bearings anyway.
Old Dec 2, 2002 | 08:30 PM
TheGreatJ's Avatar
Sounds like a wheel bearing to me too.
Old Dec 2, 2002 | 09:49 PM
Lars's Avatar
Balljoint.
Old Dec 3, 2002 | 09:23 AM
CODY BEHNKE's Avatar
With the wheel off does just the rotor move or does the whole spindle move?
Old Dec 3, 2002 | 09:31 AM
newby's Avatar
If I remember right the whole spindle moves.
Old Dec 3, 2002 | 10:01 AM
If the whole spindle moves it's most likely a ball joint.
Is the strut and mount ok?
grabbem88
Feb 23, 2015 09:41 PM
dbrockma
Feb 16, 2015 02:56 PM
willie-d-nice
Feb 13, 2015 06:40 AM
siguy
Nov 27, 2014 10:07 AM
