Heres a stupid question regarding 4th gen Rearend
Old Dec 2, 2002 | 04:20 PM
BlowBye's Avatar
I have some guy selling a rearend which came off his 99' LS1,6speed camaro. From what he emailed me it has 3.42 posi 28 axle rear. The only disadvantage is that there is no backplates or brakes on either side. I know the LT1 4th gen rears bolt on to 3rd gens, but will this 99 LS1 rear fit into my 92 camaro RS??? Could i install the Backplates and Drums from my 92 RS into the 99' Rear for the mean time????? any info or tips is appreciated thanx guys
Old Dec 2, 2002 | 05:33 PM
Chris Ja's Avatar
Eternal Member
It's the same as the LT1 rear. The only time is the diff is wider than a 3rd gen so your 3rd gen rims will stick out.
Old Dec 2, 2002 | 05:54 PM
BlowBye's Avatar
thanx man.
Old Dec 3, 2002 | 03:30 PM
Marc 85Z28's Avatar
I just finished that same swap myself. Everything bolts right up, no problems except the brakes. You will need a set of 93 or later rear disc brakes. The drums you have might fit, but it will require more fabrication than you would be willing to attempt.
Old Dec 4, 2002 | 02:16 PM
BlowBye's Avatar
I have the backplates,shoes and Drums from my 92' Camaro Rear, Couldnt i reuse the backplate from the 92' into the 99' rear?
Old Dec 4, 2002 | 02:47 PM
TheGreatJ's Avatar
I believe the flange that the backplate bolts to is different, but I'm not sure. Take a good close look before you buy.
Old Dec 6, 2002 | 09:01 AM
Marc 85Z28's Avatar
The flange that's welded onto your stock 3rd gen drum axle is very different from any other design. It will not work with later disc setups. You can modify it however. But like I said, that is not a route that you want to go (unless you have an acetylene torch and welder handy). You'd be better off dropping another $100-$150 or so for a 93+ rear disc setup. Or, if you have no money, you could put a 93-96 drum setup on. You can find them all the time at junkyards (people usually only take the disc setups) real cheap!
Your stock flange looks like this
http://www.thirdgen.org/newdesign/te...e%20Flange.jpg
You would have to cut this off
http://www.thirdgen.org/newdesign/te...0Cut%20Off.jpg
And then weld that piece to the top of the axle flange on the 4th gen rear.
A LOT of unnecessary work for some $hitty drum brakes
ChrisFrez
Feb 22, 2015 08:47 AM
ddr698
Jan 9, 2015 10:05 AM
cmdeshon
Dec 27, 2014 10:06 AM
ChrisFrez
Dec 15, 2014 03:09 PM
Brent94Z
Mar 21, 2002 04:44 PM
