153or 168 spline flexplate
Old Nov 27, 2002 | 03:45 AM
99huggerorangeZ's Avatar
Question 153or 168 spline flexplate
my 1991 camaro originaly came with a 153 spline flexplate
when i put my new engine in should i use a 153 like it came with or a 168?
what is the difference
ps i am haveing my 700r4 rebuilt
Old Nov 27, 2002 | 07:36 AM
OldSStroker's Avatar
Re: 153or 168 spline flexplate
153 and 168 are the number of teeth on the outside of the flexplate which mate with the starter drive gear (pinion). The 153 tooth is the "small" diameter (about 10.5 in.). The 168 tooth is the "large" (about 12.7 in) plate.
If the 153 tooth fits the torque converter, use it. It's lighter, and allows the starter to mount closer to the block for more header clearance. A standard GM 153 tooth flexplate weighs about 4.5 lbs.
A flex plate has a couple of functions:
1) It connects the crankshaft to the torque converter.
2) It flexes a little when/if the converter "balloons" or expands in use, hence the name.
3) It carries the ring gear (153 or 168 teeth) and puts it in a position where the starter can reach it.
Old Nov 27, 2002 | 12:18 PM
Moving to "3rd Gen Tech".....
Old Nov 27, 2002 | 01:37 PM
Question
so it doesnt matter if i use a 153 or 168 it is my choice?
Old Nov 27, 2002 | 02:42 PM
1968firebird's Avatar
Do not get a 168, go her to find out why http://www.fbody.com/cgi-bin/3gen/read.cgi?msgid=21434
RUENUF
Mar 13, 2016 03:37 PM
karpetcm
Aug 14, 2015 03:02 PM
realistyc
Jul 28, 2015 07:32 PM
alphaauto
Jul 26, 2015 04:40 PM
99huggerorangeZ
Nov 12, 2002 11:34 AM
