Starter problems
Old Nov 7, 2002 | 08:38 AM
bmillington's Avatar
Question Starter problems
Sometimes when starting the car the starter makes a awful noise and shakes and I think I can hear sparks. And sometimes it juts clicks and wont turn over or won't even click, but if I push it just a lttle and try again it will start. Or if its making that noise I stop and try again it again it starts fin. It only doea this maybe 1/8 of the time. Was thinking mybe a combination of the starter needing to be shimmed and a bad spot on the armature of the starter. Any Ideas?
Old Nov 10, 2002 | 06:51 PM
WS6Formula350's Avatar
New starter or check to see if your bolts are tight
Old Nov 10, 2002 | 09:37 PM
aklim's Avatar
It only needs to be shimmed once. I have never shimmed a starter other than during install. If the bolts are tight, take them out and examine the gear. Rotate the crank and see if the teeth are chipped. If not, you are lucky. If so, you need a new flexplate or flywheel. I'd change the starter before you get stranded somewhere. I'd take it out and look at the gears on both starter and flexplate or flywheel.
AlaskaZ28
Apr 17, 2015 08:54 AM
Oncomingstorm22
Jan 22, 2015 07:15 PM
97z28k&N
Jan 9, 2015 04:58 AM
jermaine_rashad
Advanced Tech
Jan 4, 2015 02:32 PM
Jeff1904
Jan 3, 2015 12:00 AM
