Can I use my in-radiator transmission cooler as a PS cooler?
From: Greenville, Hatteras, NC (the motor sports capital of the world)
I have a new radiator and it has the 1/4" NPT hookups for a tranny cooler but my car doesn't have an automatic. Can I route my power steering fluid through it? I know I can do it but would the high radiator temp make the PS fluid too hot?
Yes, but please make sure you do it on the RETURN line, not the high pressure line or....... POW!
Some 3rd gens already have a PS cooler (sorta). Many I have found have a long loop of metal return line that goes up in front of the radiator and makes a loop and back to the pump. I doubt it works very well but it would make finding a place to tap into to run aftermarket unit in front of your radiator super easy!
Yes the 85' Iroc Z's have the metal loop but the 85' V8's don't.
The return line is thin and the high pressure is about 3/4 inches thick and looks like a A/C compresser discharge line don't cut the thick one.
Has any one ever did this? Will the trans cooler inside the radiator heat or cool the power steering fluid? I guess that answer depends on whether or not the power steering fliud (with no cooler) gets hotter than the operating temp of the radiator fliud? Does anyone know the normal temp of power steering fluid? Thanks, Shimaze
Re: Can I use my in-radiator transmission cooler as a PS cooler?
And as far as having done this. On my 97 one side of the rad. is used for engine oil cooling and the other is used for PS, from the factory.
