Subframe connector questions
Old Nov 11, 2002 | 06:20 PM
guywidiroc's Avatar
I'm gonna grab a pair of bf drag radials, but I know that I'll need subframe connectors to keep the car straight. What are some reasonable brands?? Any links to pics of installed sfc would be appreciated. I really wanna grab a 1.79 60 ft, but well see.
Old Nov 11, 2002 | 08:24 PM
funina91ss's Avatar
SFC are great but you can run DR without them just plan a set to keep the car tight... I used Mac. no problems with them little tight on the Ypipe 3" had to move it down to clear.. I also see you have a 6 speed my mac's were in the way of my cross member when I put in the sophn setup ..I will send you a pic of it..
Old Nov 11, 2002 | 09:18 PM
aklim's Avatar
I used Alston's and am quite happy with them. They were the bolt in kind. They fitted quite well and are weldable which I did have done.
Old Nov 11, 2002 | 11:34 PM
automec's Avatar
where did you get the alston SFC ???
mike
Old Nov 12, 2002 | 05:25 AM
Tang's Avatar
I've got the Kenny Brown SFC. They look great and they went in with no modifcations having to be made. They are weld in which I hear is the way you should go. They took about an hour to install.
Old Nov 13, 2002 | 08:09 AM
toneyb35's Avatar
Cool SUBFRAMES
Does anyone make SFC's for convertibles or doesn't convertibles need them???
Old Nov 13, 2002 | 02:53 PM
Fbodychick's Avatar
I used Kenny Brown's on my 91 Z28 Convertible LS1/6 speed.
Old Nov 13, 2002 | 05:21 PM
AutoRoc's Avatar
cfhngchj
I used South Side Machine(SSM, found in Jegs possibly) in both a convertible 89 IROC and a 85 T-Top car. Cost is around $140-150. Fits great, paint them yourself, welds up nice. A large Y-pipe will get VERY close to them, I used a BFH on my SLP Y-pipe to get it to clear. No major reshaping, just a little dent. Goodluck!
Old Nov 13, 2002 | 05:55 PM
toneyb35's Avatar
Question SUBFRAMES
Should subframe connectors be the first or the last MOD or does it matter???
Old Nov 13, 2002 | 06:11 PM
Tang's Avatar
They should be the first mod you do. Almost everyone will say that.
Old Nov 13, 2002 | 06:28 PM
toneyb35's Avatar
So I can do exhaust, transmission and other under body work around the subframe connectors???
Old Nov 13, 2002 | 06:45 PM
funina91ss's Avatar
That would be the way to go..
Old Nov 13, 2002 | 06:49 PM
Tang's Avatar
Ya with most of the SFC out there you can do all sorts of underbody work without the SFC getting in the way.
Old Nov 13, 2002 | 11:31 PM
aklim's Avatar
mike
http://www.alstonracing.com/
Alston
248 West Depot, Antioch, IL 60002
(847) 395-3500
Old Nov 14, 2002 | 02:11 AM
stonedchihuahua's Avatar
I'm planning on making my own... They aren't all that difficult to make and it is cheap... I dunno anyone else made some out of box iron and angle iron???? I was planning on having them stick about a quarter inch below my ground effects since wintertime here in canada hides curbs and all sorts of ground effect destroying objects
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
QuickSilver02
Apr 7, 2015 11:12 AM
Jibberish18
Aug 28, 2002 12:46 PM
