Puddle on the passenger side floor???
Old Dec 7, 2002 | 02:18 PM
YellowZ28's Avatar
Everytime it rains hard or even for a long period of time there is a puddle on the passenger side floor. Its not coming from the ttops, it seems to be coming from behind the dash to the far right near the kickpanel. I have seen this problem in my 87 cutlass supreme as well as a friends 85 firebird. I cant figure out what this is. Can anyone help????
Old Dec 7, 2002 | 02:24 PM
87camracer's Avatar
usually that means the heater core is leaking and needs to be replaced. but you say it only does it when it rains? i would check the seal around the bottom of the windshield cuz it might be leaking there... i dunno tho.
Old Dec 7, 2002 | 02:32 PM
RamAirBird2k2's Avatar
If it has anti freeze in it it's the heater core
Old Dec 7, 2002 | 03:19 PM
YellowZ28's Avatar
the heater core was replaced about a month or two ago. Its all water no antifreeze. Im thinking it has to be that seal too i dunno...
Old Dec 7, 2002 | 08:13 PM
stanghunter211's Avatar
Mine does this too. Its because down behind the kick panels there are "access" holes for various things. When I was installing my stereo, I had to remove this rubber sheeting that was glued over the opening. Now when I wash my car, if I spray alot in the fender well area or whatever runs off the windsheild, will start to trickle into the pass side floor. I really need to get to fixing that, but I figure since I'm redoing the interior, I might as well wait and seal every leaky place on my car. he headliner sags too at night when there is a lot of condensation. The whole car needs to be sealed up good.
Well, I hope that makes sense and helps a little even. Good luck, take care of it before its starts to rust.
Will
P.S. You'd know if it was the heater core, my blew last month and that was a pain.
Jun 5, 2015 10:16 AM
kxrawx
May 25, 2015 08:29 PM
camaro98_speed
Apr 22, 2015 11:26 AM
