need help in indy
Old Nov 30, 2002 | 06:07 PM
z91bowtie's Avatar
need help in indy
what's up every body? here goes i am living know in indianapolis and my z28's oil pump is bad. my car was runing pretty quick for a 305 tpi with 5 speed. but know my engine is shot. the crank bearings sound like a helicoptor. i have looked in the indy phone book for an engine but there price's are are to high i don't know were to look for one but if any indy guy's with any idea on where i can get my engine rebuilt or if i can throw a 350 in it that would be great also. if i go with a 350 what besides my computer will a have to change and will it work with my 5 speed. and is there some kind of camaro club in indy. thank's for your help guys
Old Nov 30, 2002 | 06:19 PM
87camracer's Avatar
i dont live in indy but i can tell you a little about swapping in a 350. all you will need to do is go to a junkyard and pick a clean appearing 350 block, MAKE SURE ITS A 350, take it to an engine shop and have them take a look at it. if it turns out clean then build the bottom end however you want, my advice is to bore it out .030 and get a 350 rebuild kit from a place like jegs. make sure that if you do bore it out that you get .030 over pistons too. then find a retailer for pro lightning heads. these are great heads that flow as good if not better than a set of AFR 195 aluminum heads. the lightning heads go for about 700-800 a pair. then go to www.lt1intake.com and talk to john millican and have him set you up with a converted LT1 intake. drop in the motor and get a 350 chip to feed the injectors. you may have to have a custom prom burned so you might check into that. after that drive it until the 5 speed grenades and i GARUNTEE you that it will. find a cheap used 6 speed and drop in. and then have fun. that would be a nice recipe for a great running 355 SBC that *should* make around 400 hp or so.
also i didnt suggest a cam because i dont know what kind of driving you would need it for. if you go with that setup, call comp cams info line, (number located at www.compcams.com and ask them) they should be able to set you up with the PERFECT cam for your setup. hope this helps
IndyZman
Oct 22, 2015 02:17 PM
NewsBot
Apr 11, 2015 11:44 AM
cmsmith
Mar 14, 2015 03:48 PM
Fbodfather
22
Dec 21, 2003 05:59 PM
NineSevenWS6
Jun 5, 2003 11:15 AM
