Flat Spots On Tires
Old Nov 13, 2002 | 08:46 AM
toneyb35's Avatar
Cool Flat Spots On Tires
My car sat up for about four months without moving. Now I have flat spots. Is there anything I can do other than replacing them???
Old Nov 13, 2002 | 09:26 AM
91RS5speed's Avatar
Drive it some and see if it evens out.
Old Nov 13, 2002 | 11:06 AM
walrus108's Avatar
They should be fine. I've had this happen more than a few times. It will help to run them about 5-10lbs low on pressure for 20-50 miles or a few days(depending on how far yor drive daily). They will go round again.
Old Nov 13, 2002 | 11:48 AM
TunedPort 335's Avatar
Do a couple nice smokey burnouts, and that will cure the rear tires !!!
Old Nov 13, 2002 | 11:53 AM
Marc 85Z28's Avatar
That will make it worse... Flat spots have nothing to do with the tread. It's the polyester and steel cords in the tire that are the culprits.
As suggested above, run the tires at around 25psi for a nice long trip so the tires get nice and hot.
Old Nov 13, 2002 | 06:05 PM
toneyb35's Avatar
Cool
Hey thanks guys. I thought I would have to replace them.
Old Nov 14, 2002 | 08:46 PM
citizendan1st's Avatar
good call
hey good call on the running on low air pressure...
the steel belts need to be worked round again..
kinda like bending a piece of wire straight..
if you lock up your brakes and cause those kind of flat spots..you can possibly burn those off...
losing a few thousand miles off the tread..
do as he says with the air pressure and all will be right..
good luck and have fun..
peace.
Dan
Victor Lamb
Aug 26, 2017 02:52 PM
Jasonz28camaro
West South Central
Jun 7, 2015 09:12 PM
4586
Apr 29, 2015 01:43 PM
KYWes
Apr 3, 2015 07:59 PM
squarehead
Nov 21, 2014 08:02 PM
