Oil Pressure
Old Nov 9, 2002 | 01:57 PM
WTF's Avatar
WTF
Angry Oil Pressure
This is a messed up problem, I hope you guys can help. I have a 92 Z28 W/Rebuilt 350TPI.
the oil pressure will drop almost to the redline when there is a load on the engine, but if I'm cruising on the highway it's fine. Also, after I chagne the oil I don't have this problem at all, it's only when I get about 1800-2000 miles on it It's really pissing me off! Can you guys help me out here???
Old Nov 9, 2002 | 09:12 PM
brodyscamaro's Avatar
change your oil every 1500 miles
Old Nov 12, 2002 | 07:27 PM
WTF's Avatar
WTF
Red face
Thanks Smart ***! Butthat doesn't really help me much
Old Nov 13, 2002 | 11:08 AM
fbird95's Avatar
If the oil level ok, i'd check out the integrity of the gauge. The gauge could be bad.
Old Nov 13, 2002 | 11:58 AM
Marc 85Z28's Avatar
The guage? How would the guage only react to higher mileage oil? You should check the sender. Make sure the connections are good. Makesure its clean - any crud or buildup could cause a false signal.
Old Nov 13, 2002 | 08:45 PM
ws6gta's Avatar
he's right,check the sender .I had a similar problem,changed the sending unit ,and the problem went away.if I remember right it was under 15.00
Hope this helps
Old Nov 14, 2002 | 08:38 AM
WTF's Avatar
WTF
Thanks for all the info guys, I'll check on that sender this weekend!!
-Marc-
HectorM52
Jul 30, 2017 11:46 AM
Nickster 7
May 1, 2015 09:04 PM
surreybrad
Apr 22, 2015 06:40 AM
KYWes
Apr 15, 2015 05:48 AM
ad356
Apr 11, 2015 08:49 AM
