fastest 5.0
Old Nov 29, 2002 | 08:28 PM
6-Fitz's Avatar
Question fastest 5.0
I'm curious to what is the fastest n/a 5.0 on this board and what were your mods?
Old Nov 29, 2002 | 09:29 PM
VortecZ28's Avatar
as in SBC 305? or ford 302?
the quickest 305 Fbody is 'baddest305' I think with 11.6@114?
Old Nov 29, 2002 | 09:41 PM
6-Fitz's Avatar
Smile
I'm talkin 305 the real 5 liter. Ain't baddest 305 juicin? to get those numbers? although impressive but not naturlly aspirated.
Old Nov 30, 2002 | 01:39 PM
baddest305's Avatar
13.0-13.1 on motor
11.60 @114.9 on spray
Old Nov 30, 2002 | 01:48 PM
Chris`s85Z28's Avatar
when you say 5.0 people think Mustang so thats why we say 305 mine runs 14-15? maybe I don`t know I went down .4km in 13.4 sec I think thats close to a 1/4 mile baddest 305 thats a awsome camaro
Old Nov 30, 2002 | 03:33 PM
funina91ss's Avatar
I have ran a 9.23 8th mile with a stock block&heads&TBI!
Here is my Buddys car it ran 8.26 8th milebuddys car link
Old Dec 1, 2002 | 09:53 AM
WickedZ's Avatar
crazeinc on www.nethirdgen.org is pretty quick, but I don't know the specs on his 305. I have run 13's with an LG4, it was some years ago, an '87Z28, and it wasn't entirely cheap to do, in say, comparison to get an L98 to that point, for instance. I will try again, but I'll bet it either will take me a lot of weight reduction, or a little go-juice to make it happen.
BTW: Baddest305: That is a very sweet ride! Good job!
I will try this route:
Home-ported LG4 heads
1.6rr, hardened pr, larger valves
.030-over block, Keith Black pistons
roller cam/lifters, doner TBI shortblock
Edelbrock Perf. RPM Intake & 600cfm Carb
AC/Smog delete
Accel HEI components, wires & AC plugs
Hedman Hedders, custom y-pipe Catco Cat & Hooker Aerochamber catback
Lakewood rear components
Welded spider gears, 3.73 ring & pinion
1LE Driveshaft, 16x8" ARE Wheels w/BFG Drags
Prepped 700-R4 w/B&M Holeshot 3000 converter
Most of the work is already done, minus the block prep and just installing this thing in the car, haven't made a decision on which cam just yet, or fuel pump, since I am still skeptical on the whole elec. pump configuration on my used-to-be mechanical setup.
Old Dec 1, 2002 | 04:50 PM
RobsWS6's Avatar
I ran a 13.89 back in '87 with my 84 Z28 HO 5spd.
Mods were(if I remember correctly )
K&N, 160 thermo, removed charcoal ring in air filter, timing 14 degrees, air pump belt removed, gutted cat, Hypertech Stage II chip, and 235/60/15 Euro TA's.
I think that was it.
P.S. Sorry to hear about the Spirit. I had a 92 Spirit R/T. Bone stock it ran 14.4 with a 2.6 short time. Never went back after that but raised the boost and it was an easy 13 second car.
Old Dec 1, 2002 | 07:42 PM
6-Fitz's Avatar
thanx for the thoughts ws6 I managed to get that mopar back on the road. It was'nt cheap and hence it needs to go down the road. As for calling a 305 a 305 instead of a 5.0, I like 5.0. I like these engines. It doesn't take as much money as most would believe it takes to make these engines perform, unless you have a tbi. In fact when I had mine, it took ported stock heads, doing all the free mods and intake clean-up and headers to get my #s. Almost forgot, 1.6:1 roller tip rockers. The car was an '89 I-Roc 5 liter m5 w/ 3.08 gears. I loved eating up lt1s and pisstangs mod for mod ( that's referring to the pisstangs). I miss that car from time to time can never get enough of these schmucks out here that hated on me cause their car got beat by my 5 liter. Now I have the T and I get tobeat up on a whole new batch of v8 guys including some v10s. The amount of money I spent on that 5 liter was prolly under 1g.
Old Dec 1, 2002 | 07:44 PM
6-Fitz's Avatar
Oh BTW, baddest 305, that is an awsome car! Keep layin the smack on those pathetic ponies and just laugh at those imports as you are sippin on a cool refreshment.
Quickss96
Jan 29, 2016 05:56 PM
Henson071
Dec 30, 2015 09:55 PM
Henson071
Sep 18, 2015 04:01 PM
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
Boss002
Jul 9, 2015 03:33 PM
