- Grinding Noise from rear of car
- Removing the A/C system...
- Weird problem
- Anti Rice
- TB or IAC problem??
- How To Rig Up Exhaust With Long Tube Headers?
- Installing a custom alarm: need power lock schematic
- Which Ground Effects Look Better?
- Motor ID #
- stupid trans question....
- Help Picking out Gears...
- miniram & thermostat housing?
- RE: Thermostat
- 80 series vs 40 series vs aerochamber
- help help help please
- Gears in rear???
- 3rd gen ???'s
- MiniRam question-
- 350 TBI motor questions
- How much to advance timing?
- swaping motors.....
- Engine swap decision
- Will this cold-air intake fit on an 82 carb?
- Few 4th gen > 3rd gen part ?'s
- yo guys i need a lil help on this
- headers
- What is a cold start problem...? Maybe thats my prob...
- What would you do with $5,000?
- gmhtp fastest l-98 in the country
- carb help
- mad dog transmissons
- will LT1 accessory brackets fit a sbc?
- Which Strut Tower Brace?
- What go-fast part next?
- HSR Fuel Pressure and Timing Question...
- Installing a kill switch to prevent theft
- EGR removal from TPI
- Where to hook up an oil temp gauge sender
- SFCs arrived today!
- belt routing without AC
- why do i have only one tranny cooler line going into my radiator????
- How does a 305TPI look different than a 350TPI?
- Frugal Formul??? Any updates????
- Open Element w/ Cowl Vs. Stock
- Dressup
- this is weird
- Should I be running Premium GAS?
- TH400 or TH350
- Temp Gauge not workin..
- I found the runners, but no plenum?
- Checking fuel pressure on a carbureator and a problem with my car.
- Any Solid Advice
- 1989 Iroc TB problems
- Passing emissions with headers with motor swap.
- TPI faster then new Z
- Fog light bezels anyone???
- Sequential taillights (revisited)
- Gettin frustrated
- dash swap
- anyone know how to tell a T/A from a GTA by different parts?
- Casting numbers
- HSR Stroker Motor Has A New Home
- Replacing Factory Q-Jet with Edelbrock
- hopefully all everybody with grand national expertise help!!
- ???? bout overheating
- Just bought a 9 bolt posi (3 series)...what gears?
- Electric water pumps?
- becool rad install help!
- polishing question?
- any suggestions for a cat on a 86 iroc??
- the clicking, blinking choke light....
- 90 RS tranny problems
- Colder Spark Plugs?
- high power cooling?
- Torx bolts???
- what rims?
- need a radiator!
- throttle body
- Paintless dent removal or new roof skin?
- L-98
- Lets try this again....Engine problems...
- Blowing my 5A fuse
- can't gain traction
- Which muffler for my Camaro?
- SS-Hood
- SS-Hood
- Failed inspection! Please help....
- Best Color For A 3rd Gen??
- Blown axle...need help with gears!
- marbles in a metal pan
- Water Pumps....
- Noise from Rear after warm
- 2.8 bogs bad!
- no ac heater box
- tranny swap
- 1986 305 TPI intake manifold leak
- Newbie here with questions about building up a motor
- Cheap 4 Inch Cowl Hood
- Lowering Springs for 3rd Gen Camaro
- ??Anyone sell line lock kits with pre-bent lines('84 Z-28)??
- 85 trans am. just dont know
- tired of ripping my knuckles
- oh thank god, driving again
- anyone know any sure ways of telling if an ecm or memcal is bad?
- Stock temperature for a 91 camaro rs
- My heater and AC are broken: blower questions inside
- Trany cooler help (BBC Guys)
- LT1 install, what clamshells?
- HSR and 85-89 L98
- Highest lift with stock L98 springs?
- LS1 injecters?
- distributorless ignition for a TPI
- Any V6 and V8 compatible transmissions?
- Buying 4-bolt main 350 for my 86 Iroc
- am i running TOO cold? what does your temp gauge ussually read
- Jegs Has Free Shipping?!?!?
- Pictures of 4 Inch Cowl Hood
- How's this for a 3rd Gen engine?
- Engine Start Up
- Getting more horsepower...
- Bleeding brakes
- Newbie Engine Recommendations
- Tranny leak.....
- Exuast leak.....
- Rear End Options
- Another Overheating Problem
- tranny problems
- Fans work sometimes?
- Electrical Problem: I turn on heater and the fuse blows
- Apparently i didnt figure my problem out.
- What offset do I need on 18" rims???
- Throw out bearing / Clutch return spring
- 25th Ann camaro; certificate of destruction...
- Few questions to clear things up
- New Carb or Rebuild
- Location of MAF burn off module on TPI?.
- Camaro keeps pushing 240 degrees and went over 260 while driving today.....HELP!?
- who's running flowmasters with what tips
- 300ish RWHP...L98 or LT1?
- Dyno'd my Engine today
- at a loss...
- Still Have Engine Problems
- I might have found my next camaro
- tranny probs 700-r4
- Car wont stay on
- I can't hear my car :(
- Smoke From the Small Tubes Running to the Cylinders
- Long hard day Racing & more problems with my car.
- hatch motor electrical draw
- anyone try and put a tranny "inside" the car? to ship it i mean
- thermostat
- 91 carbed car
- Where can I find a GM Crate 350?
- Post Pictures of Camaro's with RAM AIR HOOD
- Will This Work?
- hmm, what do you think of this engine should i buy it
- thamks in advance
- stock stats for the 91 RS 305
- Drag co efficiency
- won't fire up
- TBI Cold Air Intake
- draw and high idel
- ALL L98 owners....please respond
- Car doesnt shift at all when started?!?
- AHHH!!! Lady Camaro won't start!
- carb or fuel injection
- Berlinetta, good bad, ugly?
- Dual Exhaust Kits???
- New to Camaros... Questions
- Fuel sending unit wiring question.
- Need vin number
- HELP! Trans won't stay in park
- 91 Z28s equipped with ABS?
- Hood clearence on a 3rd gen--LG4/Q-Jet....
- Price Estimate for 5 speed swap
- door panel swap
- Switching from mass air flow to speed density.
- Bad Gas????
- Air Foil, Does it make any difference?
- Questions about DFI...
- 1989 WS-6 Firebird Formula for sale
- L98's get no respect!
- Hotchkis SFCs
- Carburetor?
- head gasket blown
- 03 Cobra injectors work on Camaro
- Help. newbie looking to start a 3gen project
- Help on Timing a 350....
- superram VS. miniram
- Vapor Lock Problems
- wiring for tpi to carburetor help.
- flat spot
- New exhaust??
- pulled intake apart and now car won't start!
- First mods for 350 TPI
- Smog Stuff
- Need help/opinions..car is running EXTREMELY rich!
- R.I.P. My LB9...Help me find an L98..
- Build Sheet for '92 ?
- Need axle shaft for 86 10-bolt disc
- MAF Sensor Problem
- Is it time for new brakes??
- Don't think the car is running on all cylinders
- Air Filter
- Stupid noise
- 3rd Gen Noob lookin to buy!
- ws6
- rear end
- Found problem with my car
- new skools pull so hard compared to third gens
- angle plug heads on 3rd gens
- Auto Xray 240 maual
- why is my lg4 doing this
- Finally got another Camaro
- What Cam?
- Gauges..
- 3rd gen Speedo replacement question
- NO gears in 700R4
- Will my headers fit on AFR's?
- Car not starting when hot,, can anyone help????
- Think im Running on seven!?!
- tell my how to get my pinion seal out!!!!!
- fuel system
- bulletproof tranny rebuild
- timing cover question
- aaaaahhhhhhhhhh fire!!!!!!
- AC question
- Good price for a 90 iroc?
- fuel injector cleaning systems
- vacuum with 224/230 cam
- TBI Intake Idea
- Is thirdgen.org down?
- Carb Problem
- Need help with electrical problems
- flowmaster question
- got the k member in some pic`s too
- Horsepower
- 87 wiring harness vs. 88 wiring harness (TPI)
- Alternator Noise
- 383?
- Need A Little HELP
- new trans
- Help me figure out my CR
- 383 stroker swap
- What the hell is wrong with my Holley
- IROC overheated... HELP!!!
- HSR and cam Dyno
- spring isolators
- Rough idle, no throttle
