Code 13
Old Aug 27, 2004 | 04:14 PM
crazypurgatory's Avatar
Code 13
I'm working on my friends 89 camaro iroc.
we just replaced the o2 sensor and it's comeing up with a code 13.
witch is an open o2 sensor circuit.
any ideas on what might be causing it to set the code?
it's a new bosch.
I was told that they were having a problem with the bosch o2 sensors.
Thanks for any help.
Chris G.
Old Aug 27, 2004 | 04:18 PM
antoine's Avatar
Re: Code 13
did you clear the ecms memory of the old code after the new install.
Old Aug 27, 2004 | 05:12 PM
Re: Code 13
yep sure did the last code before I reset the ecm was a 44 or a 45 rich or lean condition too long.
so I replaced the o2 because we had no idea when it was changed last.
reset the ecm after and got the code 13
thanks,
Chris G.
Old Aug 27, 2004 | 11:05 PM
Dave89IROC's Avatar
Re: Code 13
bad connection or bad o2
Old Aug 28, 2004 | 12:26 AM
aklim's Avatar
Re: Code 13
You might have a bad wire to the ECM. For this you will need to hook up a DVOM to the O2 sensor wire to see if you are getting feedback. If you are, tap further up the line past the connector. If not, you have a bad connector. If so, you might want to tap it a tthe ECM itself to see if it si broken somewhere you cannot see.
johnsocal
Aug 29, 2002 10:01 AM
Darth Xed
14
Aug 7, 2002 12:21 PM
91Bird305
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
BigDarknFast
Jul 8, 2002 01:37 AM
