why do i have only one tranny cooler line going into my radiator????
looking in my engine compartment today i noticed that i have one line going into the bottom hole of the 2 but the top looks like it has some kind of plug in iti havent further investigated this problem, but is ther any reason why the previous owners mechanic would do that?
how bad is it to be like that, i know that hot temps are very bad for tranny
i havent been racing or ripping around too much since i bought the car. should i totally stop driving?
Re: why do i have only one tranny cooler line going into my radiator????
haha yep it was extreamly odd when i was looking at it and wondering where the other one was,
thankyou for your imput
I found the other line. it was "did you see the one under the lower rad hose?"
it was dark when i was looking for it and i thought that they would both be routed along the side of the fender
so i have both
but what is that plug thing for? the one on the top
so i have both
u plug the top hole for the tranny when u put in an aftermarket tranny cooler,so look on the front of ur radiator and see if it has 1 there.
For a sensor that you don't use.
Originally Posted by Marc 85Z28
The later cars used that hole for an electric cooling fan sensor.
nope, it is for the optional coolant level sensor
if needed, the fan switch always went in the pass head
This is what I always heard,but I'm sure someone will know better.
I should have known that!
Javier97Z28
Sep 8, 2002 07:23 AM
chesee48
Aug 22, 2002 08:28 AM
96z
Aug 2, 2002 09:00 PM
