Weird problem
Old Aug 13, 2004 | 12:10 PM
GoSlash27's Avatar
Weird problem
Help!!
I've got a '91 Firebird. 305 TBI/th700.
It has been losing power steadily over the last week. It's to the point now where it'll barely maintain highway speed.
It idles normally and has normal torque (for a 305 ) below 2,000 RPM but develops no power above this.
It behaves as if it can't breathe, has a severe exhaust restriction, or severely retarded timing. Maybe insufficient fuel flow? I don't hear a knock, but the ALDL set a 43 fault code. All gauges register normal.
The exhaust is waay too quiet, the pulses feel weak and hot. When I push the accelerator at highway speed, the intake gets loud like it's lugging, but nothing from the exhaust (save a hissing noise I might just be imagining).
My first thought was that the cat disintegrated, but I don't hear any palladium rattling around in there.
So whaddya think? Plugged cat? Fuel filter? Something else?
I gotta get this pig back up to speed. Any help is appreciated!
-John
Old Aug 14, 2004 | 11:51 AM
Marc 85Z28's Avatar
Re: Weird problem
I agree, most likely a cat. When the converter on my sisters Firebird plugged up, it made no audible sound. Once removed, a solid chunk nearly about the size of a orange broke off and turned 90*, blocking all flow.
It wouldn't hurt to replace the fuel filter either.
Old Aug 15, 2004 | 10:33 AM
GoSlash27's Avatar
Re: Weird problem
I decided to tackle the fuel filter first. Heckuva place to put it, btw (I'm shocked nobody ever came up with a relocation kit).
If that doesn't fix it, I'll try the cat next.
Thanks for the replies!
-John
Old Aug 15, 2004 | 02:59 PM
GoSlash27's Avatar
Re: Weird problem
Wasn't the fuel filter....although it was horribly clogged as well. Guess I'll check the cat next.
Anybody know what clamp I need for the front?
Old Aug 16, 2004 | 07:20 AM
GoSlash27's Avatar
Re: Weird problem
The car seems to be running better now that I changed the filter, but it's not at full power. I reset the computer, but I don't know if the BLMs are stored in NVM. Does anybody know offhand?
If that's the case, I may just need to drive it awhile while it learns leaner settings.
Old Aug 16, 2004 | 10:06 AM
aklim's Avatar
Re: Weird problem
It should reset to base settings and learn from there. It shouldn't take more than a couple of minutes before it settles in.
Old Aug 17, 2004 | 09:43 AM
GoSlash27's Avatar
Re: Weird problem
Anybody know offhand what size exhaust clamp is on the front of the cat? I'm gonna pull it.
Old Aug 17, 2004 | 09:56 AM
aklim's Avatar
Re: Weird problem
Good luck. It is probably one of those ring style clamps. I believe it might be a 2 1/2 to 3 in.
timmy39120
May 8, 2015 11:41 AM
Dylan Latshaw
Mar 21, 2015 09:48 AM
Magenta_Hearts
Mar 5, 2015 07:01 AM
InfernalVortex
Jan 17, 2015 09:35 AM
97z28k&N
Jan 9, 2015 04:58 AM
