won't fire up
Old Jul 16, 2004 | 05:11 AM
yaryekcim's Avatar
Angry won't fire up
i have a 1982 third gen z28. i had numerous probs and once sorting out one thing, something else props up.
its got a holley throttle body injection conversion on it. it was back firing thru the throttle body. later found it to be piston 5 rocker arms nuts had worked themselves loose so the arms werent attched!
fitted them back and ran again, but slight popping thru the exhausts. compression revealed low about 80-90psi on the right side. (5.0 302cu)
a friend suggested i had tightened the rocker arm nuts too tight (as i did them all but i didn't do it in the right order) so i readjustaed them to the book says, and now it won't fire at al, even though i have a spark and there is plenty of fuel. dad said the timing chain might of snapped, but i can turn the crank and see the valves move so it must be ok. i had a new one fitted two months ago.
any help please becasue its been sat there for 10 weeks now and really getting frustrated with it!
cheers from the UK!
Formula Steve
Sep 19, 2023 08:31 AM
Nayr
Mar 3, 2023 08:34 PM
JJOHNROE
Parts Wanted
Oct 23, 2015 02:03 PM
95craz28
11
Sep 12, 2015 07:47 AM
Daluchman1974
Sep 11, 2015 06:12 AM
