Temp sensor resitance range?
Re: Temp sensor resitance range?
The Temp sensor for the ECM, but never mind. After two months I found the problem. Some Jack A## at the denver state police thought it would be a good idea to cut the primary fan wires and connect both fans to the heavy duty fan relay wich only come on by the temp switch (which is way to hot) and the A/c pressure. I don't know what they were thinking.
Thanks though
Thanks though
