drac unit
drac unit
I changed my rearend gears from 273 to 342 in my 90 camaro. There is a drac unit located in the car that i can not fine. From what I understand to fix this problem i change a few wires. Thanks
Re: drac unit
Originally Posted by Dave89IROC
I think you just need to change the speedo gears in the trans?
look under the car and see on the driver side where the speedo cable goin into the trans. take off 1 bolt (10 or 12 mm i believe),take off a little "C" shaped bracket and pull the speedo gear straight out. youll have to find out what gear you will need to put back in accordoing to ur ratio (3.42 for u).
Re: drac unit
Originally Posted by Rice Killer87
im not sure if its still there on the 90....but im leaning more towards the yes side.
