Tranny suggestions
Old Aug 21, 2004 | 12:32 AM
BaDDAss90RS's Avatar
Question Tranny suggestions
would anyone know what would be a good but cheap tranny i can swap into my 90 rs 305 tbi? ive got about 1000 to spend on one but i would like to make it as far under that as passible, my current stock tranny (700-r4) is pretty much shot.
any help is appreciated
thanx
chris
Old Aug 21, 2004 | 09:43 AM
aklim's Avatar
Re: Tranny suggestions
You could get a mechanic to rebuild it for that kind of money if he did it on the side. Other than that, $1K would not even cover a standard R&R with rebuild and certainly not if you need a torque converter.
Old Aug 25, 2004 | 11:31 AM
Ucantcme57's Avatar
I know of a good trans guy in Redford, MI.. He does all my work.. Had my trans rebuilt and a 9.5 2400-2600 convertor and a shift kit around 2k, installed and adjusted the tv cable for me. He did the 700R-4 in my tahoe too. that was alittle more expensive.. I had to get a whole new core.. Bad u-joints vibrated so bad that it cracked the whole casing... Luckily the transfer case held up... I stand by his work.. Been to alot of trans. guys in my life went through four turbo 400's with bad trans guys... Can't trust most of them.. and a Art Carr is way out of budget for most.. Can you get it to Redford, MI?
Old Aug 26, 2004 | 03:35 PM
onefastgta's Avatar
Find one in the classifieds here and on thirdgen.org, there are plenty of used built trannies under $1K.
Old Aug 26, 2004 | 05:07 PM
StalkerIROCZ's Avatar
I had my 700r rebuilt with a transgo shift kit kevlar bands ect. And a 2025 stall converter and it was $850 that also included a 25,000 lb tranny cooler and it wasnt a cheap rebuild either the man is very respected and known for his work. Im in rogers AR so maybe stuff like that is cheaper i dont know..
KYWes
Jun 14, 2022 06:52 AM
30th Anniv Z28
Aug 1, 2015 10:39 AM
Z28amustangklr
Jul 18, 2015 11:05 AM
GT what?
Jul 14, 2015 10:17 PM
Campbellb48
Jul 5, 2015 06:31 PM
