Wheel backspacing
Old Aug 21, 2004 | 01:00 PM
flounder's Avatar
Wheel backspacing
I have an 87 Iroc-Z..can anyone tell me what the backspacing is on the wheels?? I am looking at buying draglites for on it. Just wanna make sure I get the correct backspacing with the deepest dish available.
Thanks,
Phil
Old Aug 21, 2004 | 01:23 PM
JJEXP's Avatar
Re: Wheel backspacing
I believe it's 4.35. The most you can go on backspacing is 5 in the front and 5.85 in the rear. It'll probably be a tight fit if you go that far though. More if you buy adapters.
Old Aug 24, 2004 | 01:54 PM
Ucantcme57's Avatar
So with a 4th gen rear I could go up to 7.85" of backspacing in the rear? Two inches wider on each side!...
Old Aug 24, 2004 | 02:28 PM
JJEXP's Avatar
I just hope you don't bottom out the suspension and end up tearing up your tires/ fenders
Old Aug 24, 2004 | 05:34 PM
kandied91z's Avatar
my last rear wheels with a 10" were 5.75" bs and it had a 4 1/4" lip which was unstreetable.
Old Aug 25, 2004 | 10:43 AM
Ucantcme57's Avatar
What are you running now? What size is your rear tire? You have a 4th gen rear right? I was hoping to fit some 315's or wider but I need a 10.5 or 11 inch rim.. What backspacing are you running now?
Old Aug 25, 2004 | 05:04 PM
kandied91z's Avatar
nope...stock rear dimensions with a 10" and 6.75. with a 3 1/4" lip wouldn't go wider. i run 295's and that's plenty wide enough.
Old Aug 26, 2004 | 05:14 PM
Marc 85Z28's Avatar
I ran a 305/50r15 tire on a 15x10 wheel with 5" backspacing (drum rear) for awhile. It tucked into the wheelwell lip OK, but the tire was too tall. I would not recommend it. A switch to a 275/50r15 put me right back at 26", and only .5" narrower. I ran that size for years with no rubbing issues at all, even with 3 passengers. Handled MUCH better too!
Old Aug 27, 2004 | 01:52 AM
kandied91z's Avatar
also, remember the larger dish you have the more ******d rotating mass so you will slow your car down.
force10
Aug 10, 2015 08:30 AM
240ssLs3
Jul 13, 2015 05:06 PM
Slayer
Jul 4, 2015 03:06 PM
Ken Cemo
Mar 31, 2015 08:50 AM
camaro98_speed
Wheels and Tires
Mar 17, 2015 07:36 AM
