Just bought a 9 bolt posi (3 series)...what gears?
I have a 9 bolt 2.77 posi rear, but I just bought a 3 series posi and now I need to decide on what gears to get. I was looking at 9bolt.com and it seems that in October he is going to get some used 3.7x gears in stock.
I was planning on doing a HSR/AFR 195 heads/Cam (undecided on which cam right now). What gears do you guys think I need to get? 3.27, 3.45, or wait for the 3.7x's?
I figured that I would probably be better off building my 9 bolt up instead of getting a 10 bolt that will just break down the line when I start making some serious power and add traction.
Should I get the posi rebuilt before getting it installed? The posi rebuild kit is $135 from 9bolt.com .
Re: Just bought a 9 bolt posi (3 series)...what gears?
How do figure that? For the street you want really deep gears to get moving fast, or atleast i do. Also this isn't TPI, it's a HSR, so it won't run out of power at 4500rpm.
http://www.thirdgen.org/techbb2/show...hreadid=249605
Get some 3.73's for half price from Jason in the link above.
Originally Posted by 87DJP2001
Forget the 3:73 ratio and go with the 3:45 for the best results on the street.
I found a good deal on some 3.70's (thanks onefastgta ). I really kinda wanted some 3.45's but I can't seem to find them anywhere so I got the new 3.70's.
I figure I will have problems hooking up in 1st but DR's should solve that problem
. I'm glad I have a beater car for a daily driver too because I figure Highway driving in the Z will probably suck with 3.70's. The Stealthram should help alittle on the highway shouldn't it?
ChrisFrez
Jan 11, 2015 03:47 PM
