Carb Spacers
Old Aug 30, 2004 | 08:22 PM
splinter_cell's Avatar
Carb Spacers
Ive been searching about carb spacers. People have told me that they are a cheap mod that will give you some power. I read the 4 hole ones give you torque and the open ones give you more power in the upper rpm range. I would go with the 4 hole one.
Will I see a difference in using a carb spacer? My car is pretty much stock. The mods are in the sig. Just basically full exhaust. I still have the stock q-jet and intake manifold. I have a cowl hood so I dont have to worry about space.
Old Aug 30, 2004 | 10:57 PM
Stephen 87 IROC's Avatar
Re: Carb Spacers
Without dyno time, you're not going to see any big changes between different spacers. Many magazines have done tests and all spacers show some improvement. For years I've used an open 2" spacer but late this year I switched to a 1" Super Sucker from HVH. It's a highly modified 4 hole spacer and I've seen some local dyno results that look very impressive. I never got a chance to do any tests myself. I spun a main bearing in my engine before I made any runs with the new spacer. Next year won't be a good comparison since the engine is going to be different.
Old Aug 31, 2004 | 09:34 PM
Re: Carb Spacers
Cool, I think I am probably going to go with a 1 inch 4 hole spacer. Are phenolic spacers a lot more expensive than the other ones?
Kawi
Sep 28, 2015 09:01 AM
kylekratzenberg
Classic Engine Tech
Aug 25, 2015 10:28 PM
detroitmuscle
Jul 31, 2015 04:21 AM
BLK1997Z28
May 2, 2015 01:26 PM
IgorT.455/406
12
Jul 8, 2002 03:49 PM
