tranny probs 700-r4
Old Jul 18, 2004 | 09:57 PM
puckboy60's Avatar
tranny probs 700-r4
won't shift into park, also seems like the shifter is easier to pull than before, any ideas guys
Old Jul 19, 2004 | 11:05 AM
Dyosis's Avatar
Re: tranny probs 700-r4
Maybe the shifter linkage cable. It runs from the side of the tranny (drivers side metal piece) to your shifter.
Get under your car and try to manually shift the transmission into park with the metal piece that the shifter linkage cable is attacted to. As long as you can physically put the tranny in park then it should just be the cable.
Old Jul 19, 2004 | 05:01 PM
puckboy60's Avatar
thanks man i'll try that
Old Jul 20, 2004 | 12:11 AM
transxtreme's Avatar
Check ur trans fluid and change it. A check ball mite be clogged. sounds like something little.
Old Jul 21, 2004 | 11:29 AM
Ucantcme57's Avatar
Those cables are known, to get filed with crud, and not work they make greeseable ones I do believe, un hook and try by hand if work, then get new cable and greese the heck out of it and try to do so every other oil change
Old Jul 21, 2004 | 02:43 PM
Scrote's Avatar
Have you removed the trans pan as of reasent? If the bolts that hold the manual linkage to the pan have fallen out this will cause the sensation that you are feeling in the trans linkage itself. I have seen it happen on several occasions.
Take care,
Erik
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
drt
Sep 27, 2015 04:39 PM
z28newbie
Sep 9, 2015 10:26 AM
