cooling fan relay on '92 RS?
As I understand there are 2 relays on the firewall...one for the fuel pump and one for the cooling fan. Which one is which? The fan doesn't come on unless the A/C is on and so I'm replacing the relay to try and fix the problem.
Thanks,
Geoff
-the car is a '92 Camaro RS w/ the V8
Thanks,
Geoff
I'd say its a problem with the temp switch on the passenger side head before I would mess with the relay. You say the fan is coming on with the A/C, so the relay is sending the power. The stock fan switch is set for something like 230º, way too high.
