Where does this PLUG GO?!?!?!?!
Old Dec 8, 2002 | 09:41 PM
Mr. T's Z's Avatar
Angry Where does this PLUG GO?!?!?!?!
I pulled the motor out of my 89 iroc and I have 2 questions. ON the passengers side on the block is that a coolant sensor right under the header? Also I have a 4 prog plug by the distributor whit with a violet, grey, and green wire there is only three wires on the 4 prong plug where does it go?
Thanks,
TYLER!!!!!!!!!!!!
Old Dec 8, 2002 | 11:46 PM
mrr23's Avatar
the one in the head is to turn the fan(s) on.
the wires go to the computer for spark reference and injector firing.
http://www.fl-thirdgen.org/wiringdiagram.html
here's a wiring diagram.
Old Dec 8, 2002 | 11:53 PM
DarthIROC's Avatar
From: Teeter-tottering between Brilliance and Insanity
LOL I have that same plug sitting by my distributor just chillin, Im not sure what it does but it oesnt seem to effct performance
Old Dec 9, 2002 | 08:08 AM
Mr. T's Z's Avatar
Does it plug into the ECM?
Tyler
Old Dec 9, 2002 | 05:50 PM
mrr23's Avatar
well apparantly it's not the plug i thought it was. where does it lead to?
Old Dec 9, 2002 | 09:18 PM
Mr. T's Z's Avatar
Where we have it routed now is by the distributor it can't reach much past the distributor unless you route it on the drivers side. It comes out of the main harness that runs along the fire wall and goes to injectors and arcoss the engine bay to the drivers side firewall.
Tyler
Old Dec 9, 2002 | 09:48 PM
Mr. T's Z's Avatar
Narrowed it down BEEN doing a LOT of reseach will check ALL DATA at work tomorrw. It says in Chilton no MAP was on 89's but the wires are the identaical for the map sensor. But the plug is different than the all in one row for the map its a 4 prong with 3 wirs. shaped like a square. So where should my map be on an 89. It is different than any other year it what the manual says. I think it has dissappeared. Let me know.
Thanks,
Tyler
Old Dec 10, 2002 | 11:11 AM
Damon's Avatar
That sounds vaguely like the plug for the lockup function of the tranny's torque converter (plugs into trans). Auto trans car?
Old Dec 10, 2002 | 11:37 AM
MRZ28HO's Avatar
Question
I agree with Damon, is the 4 prong connector like this:
Also, the plug on the block (passenger's side) should be the knock sensor (above the oil pan rail). If it is mounted on the cylinder head, it is the fan switch.
Old Dec 10, 2002 | 05:15 PM
Mr. T's Z's Avatar
HAHAHA Thanks again GUYS I was at work looking on our ALLDATA computer program and found it. Now when I get home you tell me the trans that is where is goes THANKS!!!!!!!!! You guys ROCK. I LOVE THIS SITE!!!!!!!!!!
Tyler
PROUD CAMARO OWNER
KYWes
Jun 14, 2022 06:52 AM
sherwinZ28
11
Aug 15, 2015 05:38 PM
350350
14
Aug 11, 2015 12:03 PM
zajones
Jul 30, 2015 02:18 PM
Xiantyl
Jul 21, 2015 05:42 AM
