Reading DTC codes
Old Dec 8, 2002 | 11:16 AM
Russtebo's Avatar
Reading DTC codes
Which pins do I ground in order to blink the DTC's on the "Service engine soon" light? I'm actually looking to do this on a '89 corsica, but I imagine the pins would be the same as a Camaro. It is the 2.8L engine. And fear not, it is not yellow and there are no type-R stickers on this car. It is my winter beater now that the Z28 is in the garage. Thanks
Russ
Old Dec 8, 2002 | 11:23 AM
GMTech's Avatar
http://sethirdgen.org/dtc.htm
Since it is a corsica, some of the codes may be different, but alot are the same.
Also, since this is an '89 2.8, if there is a MAF code, Don't replace the MAF Sensor! There is a retrofit for these cars, from GM, to convert these to Speed Density. If you have a MAF code, email me and I'll help you out. The change is way cheaper than replaceing the MAF anyhow.
Old Dec 9, 2002 | 03:39 PM
Russtebo's Avatar
Greatly appreciated, That was just what I was looking for. No MAF codes, only 13 (O2 Sensor).
Thanks again
Russ
lt1matt
Mar 21, 2015 07:35 PM
aj2494
Mar 12, 2015 10:17 PM
dreamer1q
Aug 20, 2002 11:19 AM
91Bird305
Aug 5, 2002 01:39 PM
z28projects4ever
9
Jul 16, 2002 07:48 PM
