problem w/eibach pro-kit
Old Dec 20, 2002 | 10:25 AM
Gnboy's Avatar
just installed eibach pro kit on my 92 rs (beater) and the car sits 2-3" higher than before in the front back seems normal what did I do wrong? oh and yes it is a v8
Old Dec 20, 2002 | 10:45 AM
MRZ28HO's Avatar
Lightbulb
Two things that come to mind. First: the OEM springs are (were) at least 10 years old. They tend to sag after so many years with all the weight. Two: you gotta allow the Eibachs to settle by driving the car. It allows the springs to settle into the proper height, rather than the height out of the box. JFYI.
Old Dec 20, 2002 | 11:04 AM
Gnboy's Avatar
I forgot to mention I used kyb gr2 shocks & struts do I need to change the sway bar end links? to compensate for different springs
Old Dec 20, 2002 | 02:58 PM
kandied91z's Avatar
no, while it's a good idea to change those for the quality of your ride in turning capacity it isn't necessary to compensate for the springs.
other things you might consider are the angle at which the coil is sitting: in other words where the tip of the top coil is pointing at can vary the ride height to a degree....typically for lowest point and it pointing towards the front.
also, are you sure they are sittin right? if they aren't in the proper groove even half an inch off it can cause an uneven lift.
my guess is it needs to settle; but if it's a few inches higher then there is something wrong.
why not measure the gap between the tire and the fender? also put the tire size this way others can compare with you.
Old Jan 18, 2003 | 04:19 PM
Gnboy's Avatar
its been a while now and the springs have settled but the car still looks high
Old Jan 18, 2003 | 05:46 PM
aklim's Avatar
Go to a suspension shop and have them do a measurement of the car ride height and tell you what stock should be. Your old springs could have broken off and thus make it ride lower.
Old Jan 18, 2003 | 08:36 PM
aklim's Avatar
It's all of what you are trying to do. First get the baseline and see where your suspension sits. That will tell you how low it is from original specs. Then we can talk about why.
Old Jan 19, 2003 | 12:00 AM
90rocz's Avatar
I see something else, most Z's/IROCS came with 560lb front springs while the RS's and Coupe's had softer 380lb'ers. Now the Pro line springs are stiffer and the motor doesn't push them down as far plus the loss of ride height(or sag) but not a loss in tension.
For drag racing people prefer the softer springs with adjustable shocks, it promotes better weight transfer. If you want it lower take them and have them cut(with a saw)and the end re-flattened. Ofcourse if you love carving corners, keep those and if they don't settle(which I doubt)have them cut a couple of inches.
DON'T skimp on the shocks, they're probably the single most important parts of the suspension as far as ride, traction and handling.
A good shock with a good anti-roll bar and soft springs(380's) will suprise you! I've been in a few that rode good, took corners well but didn't float or roll heavy, and hooked up nicely!
Old Jan 19, 2003 | 12:03 AM
aklim's Avatar
You sure you can cut progressive rate springs like that without problems later?
Old Jan 19, 2003 | 09:17 AM
ebmiller88's Avatar
I'm 99% sure it's one of the 2 following things:
You don't have the top of the spring sitting in the upper spring perch correctly or you don't have the bottom of the spring indexed right. 2-3 inches is a LOT to settle further indicating something's wrong. Mine settled about 1/4" to 1/2" after 3 months, that's it.
Look at my page here:
http://photos.yahoo.com/taramiller72
Click on the first link for my Iroc suspension rebuild and look at my pics and explanations and see if you can find out what you did wrong. I cover the top and bottom of the spring and how to index them right.
Also, there is also a top and bottom of the spring. The top will be flatter than the other end, you can tell the difference.
HTH...Ed
Old Jan 19, 2003 | 09:19 AM
ebmiller88's Avatar
I don't really agree with this statement. My '91 RS has the exact same springs (BZW/NNL) that my '88 Iroc came with stock. The RS came with the F41 suspension pkg and the 16" wheels and got these stiffer springs.
Ed
liamcg97
Nov 25, 2019 05:55 PM
Matt W
Apr 24, 2015 12:54 AM
AlaskaZ28
Apr 17, 2015 08:54 AM
MIGHTYMOUSE
Aug 29, 2002 09:18 AM
TransAm4utoenv
Aug 28, 2002 11:06 PM
