cam selection for 383 Superram TPI
Old Jan 5, 2003 | 09:45 PM
i RoC U's Avatar
Exclamation cam selection for 383 Superram TPI
hey guys,
im rebuilding the valvetrain on my 383 stroker and im in need of some suggestions regarding roller cam selection.
i know this is tough with little info on my setup but ill try to give u all the info i can as i bought the car with the motor already done.
accel superram intake/plenum/runners, 58mm TB, Dart Sportsman II heads 2.02/1.60 (decked, polished/ported), 1.6 rockers, 48# injectors, accel dfi....not sure if any other info would help (forged bottom end, etc.). unfortunately i dont have any flow numbers for the heads (not good, i know), which is why i thought id ask here.
i think the superram setup with the heads im running would work well with an aggressive cam (over 230 duration @.50), but im not sure...
any suggestions as to which cam specs to go for?
help!
thx
Old Jan 6, 2003 | 07:55 PM
i RoC U's Avatar
...no one has any suggestions?
Old Jan 6, 2003 | 08:35 PM
Josh-'04 GTO's Avatar
Well...I have a suggestion or two. I do not suggest running the Superram with the Dart heads. The large runners of the Darts will not work as well in a torque biased setup like the Superram. Also, 48# injectors are way oversized.
Accel makes cams that match up to the superram. They are generally in the 218 range duration wise. I would go to Lingenfelters site as I'm sure he'll have them.
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
globalprojeff
Dec 6, 2014 04:18 PM
