Autometer A/F guage question....
Old Dec 31, 2002 | 07:34 PM
amc91z's Avatar
I just put one in my 91 Z28 and it seems to be working but when I'm just driving around its bouncing around REALLY fast...I know they are suppose to do that but I didn't think they were suppose to be that radical....anybody know whats wrong???
Thanks,
Adam
Old Dec 31, 2002 | 07:46 PM
stanghunter211's Avatar
Nothings wrong, thats just the way they work. Mine does the same and so do all of em. They are only meant to give a broad idea of whats going on a WOT. If you mash it, your readings should steady out for a few seconds, or as long as you are giving it alot of fuel. Mine reads pretty rich when I do this, simply because the motor is getting alot of fuel. If you coast downhill at say 60-65 with your foot off the gas, you will also get a steady reading.
It takes a little getting used to, but I like mine. lots of people call them christmas tree lights, but whatever. It helps me tune my car better.
Hope that helps
Will
Old Dec 31, 2002 | 07:51 PM
amc91z's Avatar
I know they are suppose to bounce but I didn't think they should be bouncing this fast...maybe I'm wrong...
Old Dec 31, 2002 | 07:56 PM
Its because the computer is always adjusting the mixture to achieve 14.7/1 A/F ratio. Unless you have an old car with no comp and adjust your air/fuel manually from the carb, your going to get this.
Old Jan 2, 2003 | 10:08 AM
aklim's Avatar
Hook up a DVOM to your O2 sensor and see what you get. I'll bet it is pretty much the same. That or hook up a scantool to your ECM so you see what the computer sees.
Old Jan 2, 2003 | 07:34 PM
kandied91z's Avatar
check your pm's!!
as far as the guage goes, it only has a purpose when at full throttle. otherwise it bounces around.........use to distract me for a week or so when i first got it.
Old Jan 2, 2003 | 11:00 PM
zupmanZ28's Avatar
If it bugs you that much, go to you local auto parts store and buy a 1 wire O2 sensor from an 86 LG4 car, there like 9.99. Then go to your local muffler shop and have them weld in a second sensor bung before the cat. Hook the AF guage up to that sensor and it will stay steady all the time...
Eric
Old Jan 3, 2003 | 06:13 PM
amc91z's Avatar
Thanks for all the help!
Adam
Kandied91z...I checked my pm's and dont' have any...
Old Jan 3, 2003 | 06:59 PM
kandied91z's Avatar
very odd......
any more info on your engine setup? numbers, specifics, times, etc. ?
looks nice.
RUENUF
Mar 13, 2016 03:37 PM
Quickss96
Jan 29, 2016 05:56 PM
IndyZman
Oct 22, 2015 02:17 PM
Henson071
Aug 4, 2015 09:32 AM
alphaauto
Jul 26, 2015 04:40 PM
