What tire size is equivalent to:
Old Dec 10, 2002 | 06:21 PM
BlowBye's Avatar
hi, really quick question i have a set of 245/50/ZR16 with (16X8 rims) tires out back in my camaro, what tire size is equivalent to that with 15X7 rims? 225/65/15????
Old Dec 10, 2002 | 06:46 PM
irocz383's Avatar
Each tire company and tread design measure deferant diameters.
Best thing to do is find out what tire you want and try to find a chart with the manufacturer of the tire specs.
I did the same thing trying to find a tire for a set of 18 as the tires I already have on my 16's.
Good Luck!
Old Dec 10, 2002 | 07:37 PM
Gnboy's Avatar
do the math, although tire manufacturers do measure from different parts of the tire they are relativly close so if you have a tire that is 245/50/16 that means the section width or "tread"is 245 mm wide the side walls are 50 percent of the section width and your rim diameter is 16 in the tires diameter should be about 69 cm. or 690mm or aprox. 27.5in.again these are estimates I did not use a calculator so these figures are not pefect
Old Dec 10, 2002 | 07:59 PM
Stephen 87 IROC's Avatar
The width is already in the tire size. The difference in height is a calculation.
section width x ratio / 2540 x 2 + rim size.
245/50/16 = 25.64" tall
225/65/15 = 26.51" tall
Old Dec 10, 2002 | 09:25 PM
Deimos's Avatar
Well
You take the first number for example 245 divided by 25.4 to convert to inches. The multiply it by the ratio. .60 for example for a 60 series tires. Take that times two and then add the diameter of the rim.
Old Dec 10, 2002 | 10:08 PM
mrr23's Avatar
225/60-15 would be the same height.
225/60-15 = 25.6"
245/50-16 = 25.7"
HectorM52
Jul 30, 2017 11:46 AM
LD Kirk
Apr 30, 2015 08:54 AM
blac94Z
Mar 6, 2015 07:55 AM
heavenly_six
Dec 10, 2014 12:23 AM
