vette brakes& probducts sport tuned suspension
Old Jan 1, 2003 | 04:18 PM
funina91ss's Avatar
Product ID: 12500S Category: Suspension Systems
Sport Tuned Suspension System - 1982-92 F-Body
Description: Designed for high performance driving applications, this suspension system will greatly increase handling, safety and looks. Kit includes: 1.25" Addco Front Anti-Sway Bar Kit; .875" Rear Addco Anti-Sway Bar Kit; Bilstein front Sport Struts; Bilstein Rear Sport Shocks; Front and Rear Hyperco Lowering Coil Springs. PRODUCT NOTES: Anti-Sway Bar Kits include grade-8 (aircraft grade) mounting hardware and graphite impregnated polyurethane bushings. The sway bars are yellow-zinc anodized (shiny gold tinted plating) and carry a limited lifetime warranty. Bilstein Sport shocks and struts are specially valved for performance use and also carry a limited lifetime warranty. The Hyperco coil springs will LOWER the vehicle approximately 1.25" in the front and 1.00" in the rear.
Price: $999.95
Sale Price: $799.00
Savings: $200.95
What do you guys think of this setup? combined with spohn lca and adj. phb with 17" WS6 wheels? for a 91 WS6 trans am
Old Jan 1, 2003 | 10:01 PM
crazyjoe's Avatar
Anyone have any input on these products?? These will be going on the '91 in the sig. All help is greatly appreciated! Thanks.
Joe.
Old Jan 1, 2003 | 11:20 PM
LT1Powered85Z's Avatar
I think that's outrageously expensive for what you get.
I know VBP stuff is really expensive...*shrug*
Eric
Old Jan 1, 2003 | 11:43 PM
sahlomonic's Avatar
If I remember correctly, 3rd gen and 4th gen suspension parts are interchangable. Having said that, you may want to check out SLP's SS/Firehawk suspension kits. I think they sell for $6-700. Please correct me if I am wrong, though . . .
Old Jan 2, 2003 | 04:24 PM
Marc 85Z28's Avatar
The rear suspension links on the 3rd and 4th gen cars are the same. The springs are not. The shocks are very similar, and may be interchangable. The fronts are COMPLETELY different.
If I were you, I'd do what I did (duh)
17" used ZR1 wheels and tires: $600 plus $300 for adapters
1LE sways used (larger and lighter than that kit): $50
KYB shocks/struts: $150
cut stock springs: free
The Biltstein are definately better than the KYB, but unless you autocross or road race - you will never notice the difference. The 1LE sways came with poly bushings and links and I picked those up for only $50. They are much larger 36mm front and 24mm rear. The front is hollow and weighs MUCH less than the one in the kit. Cutting stock springs is only recommended if your factory aren't worn out, otherwise get Eibach's Pro Kit - its a little over $200.
I made all the upgrades within a 2 week period and it is a HUGE difference. It handled well before, but I'm sure its a good bit over 1.0g with the few other suspension mods I have. I work at a Mazda dealer and have put my car up against some modded RX-7s and Miatas and they couldn't keep up going through an entire highway onramp/offramp "clover".
You can then spend the saved $ on a set of Lakewood LCA's and panhard rod, poly bushings for the front LCAs, and a set of subframes.
One other note. Weld in (not bolt in) a set of subframe connectors before any suspension upgrades. It will provide a stable platform and you'll be shocked at the difference.
Old Jan 2, 2003 | 07:07 PM
kandied91z's Avatar
that's not bad; i have a 1,200 into mine and it's all brand new.
bilstein front and back
kenny brown lca's and adj. phr
SW subframe connectors
1-le swaybars
eibach prokit (modified)
spohn TA
Energy suspension bushings
custom STB
gm wonderbar
i think that covers all the suspension, everything was powdercoated to match as well. car rides like a dream, although that may change with the new wheels.
Old Jan 2, 2003 | 09:10 PM
funina91ss's Avatar
Thanks for the info but has anyone ever used this setup? I dont think the price is that high just for the shocks and struts it is 400 and if you bought springs that is anoter 239 and I think it will ride good and handle good too... not beat your bones like my setup!but agian thanks for the info..
F'n1996Z28SS
Aug 23, 2023 11:19 PM
HarleyZ28
Oct 5, 2015 06:23 AM
C6LS3
Apr 15, 2015 09:50 AM
IgorT.455/406
Mar 12, 2015 03:39 AM
