oil guague problems
Old Dec 11, 2002 | 10:54 PM
89RJcamaroRS's Avatar
Angry oil guague problems
i have ulta lite auto meter guages in my car. the oil pressure guage is going crazy. when driving around it normal like 40- 50 psi. when i come to a stop it goes down to 0 some times then sneeks to 15 psi. then when i take off it some times goes back to zero. however when i start my car it goes to 50 psi after a couple of secs. so i dunno whats going on with this guage. all help is appreciate. i am over due and will be going in for an oil change in the morning.
Thanx
Brian
Old Dec 12, 2002 | 12:45 AM
aklim's Avatar
I hope for you sake I am right and it is a bad sender. Take the wire off and ground it and see if it goes to max. If so, try changing the sensor and it should be ok. I had a sender reading proper pressure in a Benz and it would drop to 0 at idle. On a FORD truck, it read 0 at cold startup for 3 mins but there was pressure. Both times you would have heard clattering if it was really at 0 psi. Hope that is your case otherwise, you might need a new motor.
Old Dec 12, 2002 | 02:39 PM
well i went for an oil change and they were like looked like only 3 qts came out. so i guess being low my sender was actin crazy cuz the oil that was in there wasnt enough i guess
Old Dec 12, 2002 | 08:03 PM
TheGreatJ's Avatar
If you were 2 quarts short then your oil pump was probably sucking air from time to time when the oil didn't make it back to the pan fast enough. NOT a good thing. You really should check your oil once in a while.
Old Dec 12, 2002 | 09:32 PM
stonedchihuahua's Avatar
Yes check your oil... I went a week without checking my oil and it was chirstmas holidays so I was baggen her pretty hard... checked it and THE DIPSTICK WAS DRY!! I am waiting to get the 400 together so i can see what kinda damage the 305 has to it
Old Dec 14, 2002 | 01:38 PM
Slowmaro1988's Avatar
dry dipstick= two quarts low. In my old hyundai I did this. Dipstick was dry and it took 3 quarts to get it back to normal...the car only held 4 quarts LOL
HectorM52
Jul 30, 2017 11:46 AM
Magenta_Hearts
Mar 25, 2015 10:24 AM
MattFick
Feb 15, 2015 10:16 PM
artic94
Jan 17, 2015 11:19 AM
NorthPoleDev
Dec 31, 2014 03:20 PM
