Does abyone make an aftermarket AC flange for headers?
Old Jan 6, 2003 | 01:20 AM
DarthIROC's Avatar
From: Teeter-tottering between Brilliance and Insanity
I live in Florida so Im willing to sacrifice a few hp on my daily driver for AC. I went out and bought a new compressor and all but to my horror the AC flange connects by the first manifold bolt. Well I dont have manifolds I have headers and it wont fit. Does anyone make a flange for the AC or am I gonna have to fabricate my own?
Old Jan 6, 2003 | 01:33 AM
kandied91z's Avatar
flange...?
i didn't know it was necessary; i was using dynomax headers on my car that were standard for our cars and had no problems?
i'm sure someone knows something...hopefully
Old Jan 6, 2003 | 08:13 AM
DarthIROC's Avatar
The peice that Im talking about mounts to the block by way of that first header bolt and also connects to the power steering pump and AC compressor.
Old Jan 6, 2003 | 02:42 PM
KyleBlue85Iroc-Z's Avatar
Yes, you have an '86. In '85 and '86 the AC/PS pump were on the drivers side and the main bracket holding them uses the first two bolts of the drivers side manifold. It's fabricated to arch over the first exhaust port. I put in heddman shorties and this bracket was far from right. Not only did it not fit over the first tube but it wasn't even straight. I cut mine with a grinder and made it only use one manifold bolt. Then shimmed it and reattached it using a longer bolt. I know it's not as strong of a hold as the original, but I made sure it was bolted down right and have had no problems yet.
I think that SLP makes a fabricated bracket just for this application, but I'm not sure that it will fit with other brand headers. If I were you and you didn't want to fabricate yours, I would call SLP and see what they say. You can find that part here, SLP Online.
Hope this helps,
Kyle
Old Jan 6, 2003 | 09:44 PM
docsis_stretch's Avatar
what i did was i went to a speed shop and pick up i believe was a mopar alt. spacer in crome (for the looks) and cut it to the right size that i needed worked get never had a problem
later
jay
89 iroc zl1
Jan 14, 2015 02:18 AM
hotrodyou1
Dec 20, 2014 10:05 PM
heavenly_six
Dec 10, 2014 12:23 AM
Rich_z28
Aug 27, 2002 12:20 AM
