starting problems
Old Jan 4, 2003 | 01:28 PM
ryantherock's Avatar
starting problems
ok here is the deal.. i have a 1986 IROC-Z 305 TPI....... here recently i have had some problems getting it to start... When you go to start it for the first time of the day, it will normally start flawlessly... but if i drive for like 5 mmin. and shut it off, and start it immediatley, it starts fine.... but if you let it sit for another five it will not start... it trys to start and turns very slowly, the if you do that for a couple of times it stops spinning... and then when you turn the key the lights start to dim, and some times it will make a clicking noise, and others it will make a whining noise.. any suggestions ??? thanks for any help !
ryan
Old Jan 4, 2003 | 03:40 PM
1984camaroz28's Avatar
get a new starter and you should be fine
Old Jan 4, 2003 | 04:21 PM
TheGreatJ's Avatar
Heat soak. The starter and solenoid are right next to the exhaust and when it gets hot it can bind up. It's a fairly common problem with SBC's...get a good heat shield for the starter or get a gear reduction starter that will provide more clearance from the exhaust (and more cranking power too).
Old Jan 4, 2003 | 04:59 PM
ok, thanks alot guys
Alex Barnes
Jan 24, 2015 10:21 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
HCz28
Jan 11, 2015 11:21 AM
97z28k&N
Jan 9, 2015 04:58 AM
97SSdude
Dec 31, 2014 07:43 PM
