Help w/mods
Old Dec 23, 2002 | 05:34 PM
Baseball's Avatar
Help w/mods
I have a 1987 Chevy Camaro 305 TPI. I have some problems such as worped flywheel and oil having gas in it (i think from an injector being stuck open) and smoking problems. I am getting the flywheel, injectors, and a tune up Thursday. But anyways I was wondering what knid of mods I can do to my car that will get more hp to the rear wheels. Also this summer i am looking at putting a 350 in so i dont want to put major bucks into the engine. Any advice. Thanks for your help.
Old Dec 23, 2002 | 07:57 PM
aklim's Avatar
Gas in oil usually means bad sealing of the rings, as a first thought, that is. That or a cylinder is not firing properly. 350s use 22 pph injectors and 350s use 24. I'd leave it alone because you won' t be able to get the 24 pph ones to work just right and will leave even more gas in the oil
Old Dec 24, 2002 | 04:05 AM
stk350's Avatar
Fix whatever problems you have now and save up money for that 350. I rushed my re-build and I wish I had saved up some money for things like head work cam intake port and pollish head milling, you know all the little things that make a difference. If you want to hop up that 305 though, try a thinner head gasket (little more compression). Also, your on a roll with that tune up but think about going to the parts store and getting a new set of valve springs. I couldn't figure out why my 350 wasn't makeing awsome power and I swapped out the tired springs for a set of new ones. Man it made a difference. Also, I think it's super chevy that is building a 88 z28 305 auto to run 13's and quicker. Search around for the last couple issues. Good luck.
Sunsetmaro
Sep 23, 2011 04:09 PM
ZeeS7o7
Oct 5, 2005 10:37 AM
canbaufo
Apr 14, 2005 09:21 AM
canbaufo
Feb 27, 2005 07:15 AM
canbaufo
Feb 14, 2005 02:41 PM
