SES codes and questions. HELP!
Old Dec 21, 2002 | 02:56 PM
stk350's Avatar
Took the time to put my car on a Snap On code finder the other day. Two problems. First, MAF burn off not working and the second, fuel pump voltage to low. Basicly, my car is going into limp mode. ( and still rips em loose through 2nd ) What am I to do, If I start the car it stumbles real bad and then idles high (thats when it goes into limp mode) I had replace the MAF burnoff and the ses went out for about 5 min than it came back on, once agian the MAF burrn off was bad. I need to get my car out of limp mode and running right. Also, when its hard to start there's a lot of gas comming out of the pipes.
Old Dec 22, 2002 | 11:30 PM
RedIrocZ-28's Avatar
Try replacing your O2 sensor... actually... what codes were yoou throwing? #'s please
Old Dec 24, 2002 | 03:55 AM
stk350's Avatar
O2 is brand new. Came with the headers I installed. I have also checked the 02 sensor wire to see if it had been cut or burnt through but its fine. Sorry man, I don't remember the code numbers but I'll shove a paper clip in there and see what comes up. I'll post numbers some time this afternoon.
Dzmaro
May 7, 2015 09:33 AM
lt1matt
Mar 21, 2015 07:35 PM
lax037
Aug 18, 2002 02:07 PM
91Bird305
Aug 5, 2002 01:39 PM
Z28Wilson
Aug 1, 2002 04:27 PM
