Stupid Stupid Axles
Old Dec 25, 2002 | 10:15 PM
DevilsAddvocate's Avatar
Stupid Stupid Axles
Well gotta 89 305 camaro, heard most people tell me that chevy upgraded to 28 spline axles that year, however I have also been told by a few that its 26 and 1990 was the first year that chevy did these changes. Just curious cuz i wanna replace my 3.08s with 3.73s and a limited slip differential, and I dont wanna go through the trouble of actually unbolting the rear end housing etc etc. Any help would be appreciated, thanks guys
Old Dec 26, 2002 | 04:18 AM
ebmiller88's Avatar
You're screwed...'89 year. Only way to know for sure is to pull the alxes.
Ed
Old Dec 26, 2002 | 08:38 AM
Stephen 87 IROC's Avatar
Very few in 89 had 28 spline. Only if it was made very late in the year. There's a good chance yours is only 26 spline.
Starting in 1990 all the axles were 28 spline.
Old Dec 26, 2002 | 09:55 AM
87DJP2001's Avatar
Only Rear Axle in 1989 to positivly have the 28 spline Axle shafts was the BW 9-Bolt, others were a hit and a miss until the stocks were used up. Again depends on the axle ratio for that year. Really no way to tell unless you look.
Old Dec 26, 2002 | 01:27 PM
Well doesnt that suck?
Old Dec 26, 2002 | 09:50 PM
aklim's Avatar
Not really. You could buy both from Jegs and return the one you don't use. That or take out the rear cover and count the splines carefully. I always thought that past 87 they were 28 spline?
Old Dec 26, 2002 | 09:58 PM
87DJP2001's Avatar
1989 was the start of the 28 spline axle shafts, prior years 26 splines.
Old Dec 27, 2002 | 12:16 PM
Damon's Avatar
There's nothing really wrong with 26 spline axles. I have a 1978 7.5" rear under my last 2 Malibus, both of which went into the 11s, no broken axles. However, I run them on street tires, never slicks.
I doubt the 28s are much stronger than the 26s. Neither will hold up long behind a strong-launching car. Especially not a manual trans.
Old Dec 28, 2002 | 08:49 PM
Great idea, whats Jegs return policy?
Old Dec 29, 2002 | 12:21 AM
aklim's Avatar
Well, provided you don't install it and use it for a couple of years, you could easily return it for no questions asked. I would buy both a week before the scheduled install and then return would be quick and easy.
2QUIK6
Sep 17, 2016 02:31 PM
93 RedBird
Nov 15, 2015 08:24 AM
IndyZman
Oct 22, 2015 02:17 PM
NewsBot
Sep 14, 2015 09:20 AM
cmsmith
Aug 9, 2015 07:30 PM
