putting fog lights in 1991 rs
Old Dec 10, 2002 | 12:34 AM
99huggerorangeZ's Avatar
Question putting fog lights in 1991 rs
i have a 1991 rs and was wondering if i take out the stock grill and replace it with a bowtie grill and put fog ligts in will the wiring harness have plugs for the lamps?
if not how can i hook up the lamps?
Old Dec 10, 2002 | 11:41 AM
aklim's Avatar
Well, here's the difference. The wiring harness in the cabin is all the same. I wired up the relays and it all worked. Having said that, the harness that is in the cabin plugs into some sort of transfer port where another harness contunues by plugging into the transfer port in the firewall end of the car. What does this mean to you? I kept the stock appearance in the car and on the outside too. How? I went to this harness and found that it lacked a wire to the fog light. I added a wire to the plug and got fog lights that run thru the switch in the cabin.
Old Dec 10, 2002 | 11:05 PM
Question
where is this harness located where you need to hook up the wire for the fog lights?
Old Dec 11, 2002 | 07:26 AM
Jim85IROC's Avatar
I added fogs to a friend's 85 Z28, which is pretty similar to the 91. He bought a fog light harness through the dealer. I think it was for a 2002 Chevy Astro, but I forget. Since he wanted the lights to operate just like the stock ones (on with low beams and parking lamps only), I used a couple bosch relays to wire it up. I wrote a tech article for it:
http://iroc.fbody.com/fogs/relay.html
You should find it helpful if you're going to wire it up yourself.
Old Dec 11, 2002 | 10:28 AM
91RS5speed's Avatar
You can swap the grill out for the z28 bowtie. I did it on mine looks great. I bough the foglight but never stuck them in. When I finaly do it im going to get the swich and wiring harness from a junk yard.
Old Dec 11, 2002 | 02:45 PM
how hard is it to remove the rs grille and put in a Z28 red bowtie grill
Old Dec 11, 2002 | 03:01 PM
CODY BEHNKE's Avatar
Go to my picture page ad take a peek:
Http://photos.yahoo.com/cbspeedfreak2
I added them to my 1991 RS, I used the factory switch, relay, dash switch plate, and Z28 grille.
Due to the cost of factory fogs I used aftermarket ones, you cant even tell the difference in the picture. I also made custom brackets too.
Alltogether I had under $100 wrapped up in the project.
Old Dec 11, 2002 | 03:07 PM
ebmiller88's Avatar
I put a set in my '91, but the lights themselves arent' factory lights. They look like them though. I got the lights off ebay (search "GM fog lights") and did use a set of factory brackets. I had to mod the mounts a bit though. I wired them up using a Bosch relay and this diagram:
http://www.classictruckshop.com/club...h/foglites.htm
I used the factory switch and trim plate. Not hard to do. I would have used parts of the factory harness had I known about it then.
Also, my total price was less than $100.
HTH...Ed
Jlo
Feb 3, 2015 09:41 PM
alphaauto
Jan 23, 2015 07:42 AM
Brake_L8
Jan 20, 2015 09:44 AM
siguy
Nov 27, 2014 10:07 AM
30thZ286speed
Aug 3, 2002 04:54 AM
