tranny cooler
Old Jan 2, 2003 | 01:17 AM
crakpotjoe's Avatar
tranny cooler
just wondering if tranny coolers are worth it?. . . also has anyone heard of these tranny pans with ventalation inside supposed to do the same thing as cooler only a little better from what i understand and easier to install. TIA
Old Jan 2, 2003 | 08:21 AM
2IROC's Avatar
Yes. I have one on mine car and most of my friends that have cars that are modded in anyway are the same.
Old Jan 2, 2003 | 10:18 AM
aklim's Avatar
If you are running it as a street vehicle, you are fine with the stock setup. However, if you are beating on the tranny or towing, you should get one.
Old Jan 4, 2003 | 07:55 PM
PLANT PROTECTION's Avatar
They are cheap and don't do any harm, they are Win/Win.
Old Jan 4, 2003 | 09:05 PM
1984camaroz28's Avatar
There worth Every pennie Deff get one
Old Jan 4, 2003 | 10:07 PM
Stephen 87 IROC's Avatar
If you use a stock torque converter then the stock cooler in the rad is fine. Since an F-body won't pull any heavy loads, it's hard to overheat the tranny.
If you use any sort of aftermarket torque converter or pull/haul heavy loads with a truck then an external cooler is highly recommended. Higher stall converters build a lot of heat because they slip more at lower rpms. Heat is the #1 killer of automatic transmissions. You need to keep the tranny oil around the same temperature that the engine runs at 160-195*.
Extra protection is to buy a tranny cooler with it's own electric fan. That way it can be mounted anywhere.
Mikes 1994 z28
Oct 10, 2015 07:55 AM
68camaroboltz
Oct 5, 2015 01:46 PM
Bxlt1
Sep 29, 2015 03:18 PM
drt
Sep 27, 2015 04:39 PM
