race
Old Dec 15, 2002 | 01:59 AM
stevem's Avatar
race
my buddy just bet me 100 dollars that his rabbit will beat my car next summer when they are both on the road.
before you get all its a 4 on me listen
its an older rabbit with a 2 liter motor 8 valve head,dual carbs,
cammed(barly idles)
he took out a newer ss on a roll to 170 km
this car ****ing hauls.
he is pulling the motor and doing even more this winter
I have built a 383(specs below)
i made sure the race was going to be quarter mile and from a standing start(my advantage)
Old Dec 15, 2002 | 02:15 AM
Chris Ja's Avatar
Eternal Member
Not knowing what all he has done and doing it's hard to say. There are imports running in the 10. around here.
What are you going to be running for a induction system. I run a SuperRam on mine. You are going to have to do something or the engine is going to starve for air. I would go with a Mini Ram because they are easier to work with. Also you are going to have to do some rear suspension work to get some traction and plant the rear tires. If you don't have DR's get some. Also take the front sway bar bolts off so you get some weight transfer. Hope that helps.
RUENUF
Mar 13, 2016 03:37 PM
Daluchman1974
Sep 11, 2015 06:12 AM
94ZinEdgewater
Sep 8, 2015 09:55 PM
Slayer
Aug 17, 2015 03:55 PM
karpetcm
Aug 14, 2015 03:02 PM
